Question about Maytag Neptune MAH5500B Front Load Washer
Lr on display
Hey Kevin - we think it is the main board. Is there more than one kind of mainboard for the Maytag Neptune?
    Genius:
  • 1,847 Answers
I have given you the site where you can find the picture and part mentioned. just click on the picture and order it.
Posted on Jun 25, 2008
What is the wiring and winding?
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak Maytag Neptune washer motor/motor control circuit board ...much this is very helpful, my machine is coming up with a "Lr"code which I believe .
Aug 20, 2015 | Maytag Neptune Washing Machines
We have a maytag neptune washer and it is suddenly not working and displaying a code of LU it kinda looks like>?
perhaps and lr??? LR--- means locked rotor assy. you will need to replace your motor control board and motor assy, comes as a kit not a bad repair (NEPTUNE REPAIR KIT) if thats indeed the issue you seeing that is
Oct 09, 2010 | Maytag Neptune Washer
Maytag washer top load neptune
See this post for troubleshooting the Lr error code. . http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
Lr is locked rotor. My first thought was that this could be a Motor Controller issue. This owner replaced tried that and it did not resolve the issue. He then replaced the main Control Board and that fixed his machine. Without known good parts (Control Board Motor Controller) this might be difficult for a DIY fix.
The Service Manual for reference. Sears Parts Direct for reference.
If you are going to try to DIY the repair I will see if I can help……Rich
Apr 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
LR CODE ON A NEPTUNE 55OOBWW WASHER
Hello there:
The LR error on your non-spinning Maytag Neptune is usually, thoughnot always, accompanied either by a burn spot or a blown fuse on theMotor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge)Either way, it means just one thing: a new motor and motor control board kit are in your future.
Hop this is very helpful for you
Best regards Michael
Dec 29, 2009 | Maytag Washing Machines
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune reads "LR" when its supposed to spin but doesn't spin what doe this mean
HI, the (lr) represent a Motor malfunction. this is commonly caused by a faulty Motor Control Board. you can confirm by inspecting the wiring harness that connects the MCB to the main control. if the harness is in good condition, replace the MCB.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune modle MAH6500AWW
it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
Apr 12, 2008 | Maytag Neptune MAH6500A Front Load Washer
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
