Question about Acer Aspire 5610-4648 Notebook
Acer3100 bios password
I am a new laptop owner and instead of leaving things alone i set a bios password and now when i turn it on just enter password comes on but it will not take the password iam locked out.try it 3 times and it reads
system disabled 14333 i shut it off and it gives me another 3 cracks at it
help!!!
    Genius:
  • 2,028 Answers
You will need to contact Acer support. You can find the contact info at Acer's site. In the future it might be a good idea not to set a bios password, usually a Windows password will suffice.
Posted on Jun 25, 2008
How to disable HDD Bios password in dell Optiplex 990?
The easy way to clear the bios password and reset bios is to take out the bios battery and start computer for about 10 seconds and then turn it back off and replace the battery. When you turn it back on you may need to go into the bios and reset everything the way you want it, and don't forget to rest the time and date.
You are welcome
Aug 30, 2015 | Dell Computers & Internet
HOW TO UNLOCK DELL LATITUDE E6420 PASSWORD = 1D3B
Contact Dell, prove ownership and they may be able to help.
Feb 26, 2015 | Dell Latitude E6420 14 Notebook Core i5...
I want to remove the bios password,,any help?
If you know the bios password, when booting up, strike the key which is indicated on the boot screen which enables your laptop to go into the bios setup. Then go to the security area, and type in the known password, when it shows the area for a new one,leave it blank, and hit save... it will save the new setting as NOT having a password at all. IF you do NOT know it, sdo the same procedure, but instead of going for the password area, select the option to change the entire bios back to default, or optimum settings. this will sually wipe out any saved things. IF neither works for you.... then take it to a professioanl and have the battery inside removed for at least 30 minutes, and when put back in, all remaining information will have been lost in the bios, effectively erasing the bios password...
Feb 22, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
It says enter unlock password what is it
Acer locks down the BIOS on there computers. The unlock password it is asking for is probably the password to unlock the BIOS. If you do not know what the BIOS is or why you would need in it, it is best to leave it alone and ignore the message. Also, from some quick research, unlocking the BIOS may void your warranty.
Jun 09, 2012 | Acer Aspire One D250 Netbook
How to remove BOIS password for hp 6720s? battery is removed but still blue screen with key on it
1) Turn off computer
2) Disconnect AC adapter
3) Remove battery pack, and remove the laptops keyboard
4) Disconnect RTC (Real Time Clock) battery (located underneath the keyboard, the red/white wire)
5) Leave off for fifteen minutes
6) Reconnect the RTC battery and reassemble the laptop
7) Reconnect AC adapter (DO NOT REINSERT THE MAIN LAPTOP BATTERY AT THIS TIME!)
8) Turn on the computer and enter the BIOS by pressing F10
9) Set the new BIOS password and save all settings.
10) Turn off the laptop and reinsert the battery
Hope this helps ...Lee
Nov 07, 2011 | HP Compaq 6720s Notebook
Forgot username and password for IBM thinkpad x41
Back up your most important data to an external storage device in case anything goes wrong while changing the BIOS settings. Remove any disc that is currently inserted in the IBM Thinkpad X41's disc drive.
2-Shut off the Thinkpad X41 laptop. Turn the laptop back on and wait for the "To interrupt normal startup, press the blue Access IBM button" message to appear on the screen.
3-Tap the blue Access IBM button at the top of the keyboard. Click the "Access BIOS" button when the "Rescue and Recovery" menu appears.
4-Click "Yes" and wait for the BIOS to load. Type in the current BIOS password for the IBM X41 and press Enter.5-Navigate over to the IBM's "Security" heading by tapping the right arrow key twice. Scroll down to the "Supervisor Password" listing and press "F5."6-Type the IBM's current BIOS password and hit Enter. Leave the next field blank if you want to completely remove the BIOS password, or instead type in a new password to replace the old one. Press Enter.7-Press "Escape" and then highlight "Restart" and press F5. Navigate to "Save changes and Restart" and press Enter.
  • Nov 05, 2011 | IBM ThinkPad X41 Tablet PC
    Previous owners password wont allow me access the acer 5580 laptop, how do i access thanks david
    Hi dcalchin...
    1. Keep pressing "F8" as the laptop computer starts.
    2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
    3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
    Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
    4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
    5. Restart laptop and login into the account you just created using your new password.
    Please take time to rate me
    Aug 28, 2011 | Acer Aspire 5580 Notebook
    Remove toshiba password from bios satellite 3000-x4
    The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
    1. Turn off your Toshiba laptop.
    2. Wait 30 seconds and turn your laptop back on.
    3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
    4. Enter your existing BIOS password and press "Enter."
    5. Press "F2" again to enter the BIOS, if prompted.
    6. Use your arrow keys to select the "Security" tab in the BIOS menu.
    7. Use the arrow keys to select "Set User Password."
    8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
    9. Enter the current password into the "Old Password" prompt and press "Enter."
    10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
    11. Press "Enter" again to confirm the new password.
    12. Press "F10" to save your changes and exit.
    I hope you find it very helpful. Best regards.
    Aug 16, 2011 | Computers & Internet
    Password BIOS prompt comes up and do not know what to do.
    Type the BIOS password, then press the Enter key.
    If you are the Owner of the laptop, and did Not setup a BIOS password, then try this:
    1.Type Password, press the Enter key
    Or,
    2.Type Administrator, and press the Enter key.
    Or,
    3.Press the Enter key, and do not type anything.
    If this is not your laptop, and the owner set up a BIOS password, you are locked out.
    Dec 20, 2009 | Toshiba Satellite 2415-S205 Notebook
    Bios password
    if you know the password, then when you go to change it instead of entering a new password just press enter on the keyboard. If you don't know the password try, admin or administration or even the word password.
    Oct 30, 2008 | Acer Aspire 5520-5908 Notebook
    Acer Aspire 5610-4648 Notebook Logo
    96 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
