Car Audio & Video Logo
Posted on Nov 30, 2010
Hi i have a eonon e1015 when trying to play a dvd it saying no disc and the same with music cd.sd card works fine radio works what could be the problem thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
392
Points
  • koticas Jun 22, 2011
    I also have the same problem and I have made NOT YET
Eonon d5150 screen problem
I Just bout an r32 mk5 golf 4motion and it has eonon unit. The touch screen not working I can not move up or down the icons to turn blue tooth on. Or anything cant select between USB stick and sd card and not showing any maps the touchscreen not in any operation at all. Has anyone had this issue
2answers
Can I play movie discs in my wii?
If it's hacked you can play movie discs, if not just if the movie is in DivX, Avi, MPG or MOV format and you play them from a SD card.
2answers
Hi i have a eonon e1015 when trying to play a dvd it saying no disc and the same with music cd.sd card works fine radio works what could be the problem I think its laser problem thanks.
I just installed a new eonon 1015 and i cant paly any CD or DVD, it seas that there is no diskt....i think i have installet correctly, but there is another orange cable wich i didnt know where to connect...can you hel please ?
3answers
I have eonon e1015.when i put disc in it it says no dise.can u help me with this
are you trying to put burnt disks in because only certain types of writable disks work on that system
Cant play computer disks such as pictures
Computer disc are written in a format that PS3's read, if you want to play photos or what not you need to burn your disc using like Nero or Power DVD to say the least, you need to select picture CD not DATA or otherwise.
If your doing music you need to burn using make music CD not just drag and drop.
Try burning using picture CD format then update me with any questions you may have or problems that may arise from this solution.
Hint!
If you got a SD CARD you can put the photos on it and the ps3 will pick those up just fine!
Let me know how it works out.
Thanks
Ed aka rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
16helpful
When i put a dvd in my eonon e1015 it says please stop watch vidio player. i dont know what this means can you help?
for your safety, eonon would not allow you to watch video while you're driving
but you can connect the brake wire to the ground wire, then you will able to watch DVD while driving.
4helpful
Eonon e1015...works correctly<touch,sound>except IMAGE
I had that problem and I looked for someone who can fix the flex cable, mine's working now. He told me the part of the flex cable is seated on a chip and it was burnt due to overheat.
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
[email protected]
Will not play CD-Rs
DVD players will play CD's and MUSIC CD-R's. Some will play MP3's IF the unit is so designed. You would see the 'MP3' logo on the front.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
