Question about LG Washing Machines
LG Washing Maching
Door will not unlock !
  • 95 Answers
Make sure the timer is set to the off position. some models are equipt with a locking feature on the door, such as a self cleaning oven door. if it still is locked, check around the door latch for an obstruction
Posted on Jun 25, 2008
Door is still locked after 2 days
I have linked a youtube video with a few methods of how to open a stuck washing machine door.
How to Release Stuck Washing Machine Door
Oct 10, 2017 | Hotpoint WMA11 Front Load Washer
I have a washer machine LG model WM2455MG and it smells terrible inside and it needs a treatment clean inside but i dont know how to, neither what to cleanit with. please help
Hello, it the inter tube seal that gets mold and other debris under this seal. I would say that most side door washing machine suffer from this aliment., Check with LG support and see what the have to eliminate this common occurance in side load washing maching Try a cup of vingearn when washing a load of clothers. GB...stewbison
Sep 13, 2011 | LG WD-12124RD Front Load Washer
Model - LG F1480FD. Need to replace drain hose. Please advise best way to get in to replace drain hose (? from bottom side etc.)
underneath......
drag maching to outside door and let old hose hang outside
this will drain alot of water out of machine then upend it to replace old hose with new 1
cheers
Mar 27, 2011 | LG WM-1480FHD Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw)
I keep having a dE error message on my LG washing maching
Samll d with big E = Dorr Error. (Cap D with E = Drain Error) Replace your door lock / latch. To get to it, you can either take the spring clamp off the tub seal around the outside of the door opening, removing the outer part of the tub seal, or if you have long thin arms, reach it from the top once you have removed the washer's top. Remember to unplug the machine before working on it.
Mar 06, 2011 | LG Washing Machines
Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Aug 19, 2009 | LG WM2688H Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Washing Machines Logo
83 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
