If the
dryer runs, but does not heat, the following link explains how to troubleshoot an electric
dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heatFirst, begin by unplugging the
dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some
homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage
reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the
washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All
dryers are not constructed the same. However, the Heating Element is located inside a
heater box. The Thermal Cut-Out (TCO) will be located on the outside of the
heater box on the end opposite the heating element terminals. The Hi-Limit
Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit
Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
On the dreyr model you have listed, all your heating circuitry is on the rear of the dryer. Just unplug and remove the back panel.
The part number for the TCO/Hi-Limit Thermostat replacement kit is 279816. The Heating Element is 279838.
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the
best price.
If you have any questions, please post back with your complete model number so that I may be able to provide you with better assistance. I hope you find this
information helpful.
NOTE: Although your assessment of a bad heating element is a good one, the TCO usually fails first.
Elec or gas dryer?
