Question about Micro Innovations MCNIC50C Webcam
Help i followed the instructions. installed the program from the disc that came with how do i use it and or know that its working.. thanks
  • Anonymous Nov 09, 2008
  • huejotzingo Dec 28, 2008
  • 8,596 Answers
All your answers can be found here:
Posted on Jul 03, 2008
How to install photshop cs5 in my sony vaio SVE14116GNB
Be sure you put in the disc for the 32 bit version and follow the installer instructions. If the installer does not start run the setup program on the disc and follow the on screen instructions.
Jan 26, 2013 | Computers & Internet
I'm trying to run my Hypertech ECON programmer for my 2010 Silverado, when I install the disk it gives me a error code 2869 and exits me out of the install. Am running WIndows 7
It seems that Windows 7 is not compatible with this program and thus the error 2869. the program in the Program Compatibility Assistant utility in Windows 7.
then select the caption that says it ran on a previous Operating system ( that is Windows XP/ Vista etc. and select the radio dial to the left and click apply.
Instruction from Windows help:
Run the Program Compatibility troubleshooter
Click to open the Program Compatibility troubleshooter.
Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Sep 25, 2010 | Computers & Internet
Sir i purchased hitachi camera pen. it is detected
If you have installed the program. Uninstall it.
Unplug the pen (or any devices associated with it) from the computer.
1. Insert Disc and intstall the program.
2. When prompted, insert the device into the computer as instructed. Follow all instructions.
3. Once installed, remove disc, restart computer.
4. The computer will detect the device as the computer is loading. Wait for all "start up" programs to load, then select the program and it should open and operate.
If it is plugged into a USB Port, and is not being detected, try using another port. Do not plug such utilities into a Port Adapter, as it most likely will not be detected.
It must be plugged directly into a USB Port installed on the computer (or laptop).
Please let me know if you need further assistance.
Guru, Premium Expert @
Jul 17, 2010 | Hitachi Dynamic Link Manager 5.4...
How can I install an older version of creatacard on Windows 7?
Open the Program Compatibility troubleshooter by clicking the Start button and then click the Control Panel. In the search box, type
troubleshooter, then click Troubleshooting. Under Programs, select run programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you can't install the program, insert the installation disc for the program and, using the troubleshooter, go to the program's setup file. It will be called something like, "Setup.exe, Install.exe"
It won't work on .msi file name extensions. There are a lot of problems running older graphic intensive programs like yours. The other thing you should try is going to the software's manufacturers website and look around for a software update that will help it work in 7.
The easiest, most generic way to find updates is usually under the help file the program. Sometimes it is listed separately under that menu, and sometimes it is under "about." Good luck, and happy holidays.
You can help me to help others by letting me know if this solution addressed your problem by rating it before you leave fixya. Thanks.
Dec 26, 2009 | Computers & Internet
How do I add sound to my computer?
It has to be have CD Support Utility Disc available of your PC.. Use it to install audio sound card and run it in your PC.
This are free software. Just follow the instruction needed to install high definition audio.
If i am helpful to you, please rate me.
Thank you.
Aug 27, 2009 | Computers & Internet
I want to install Microsoft office programs. same as word, excell etc....
Hi here's my take on this:
1. Make sure you have the disc of Microsoft office programs.
2. insert it in the cd/dvd rom.
3. double click on my computer.
4. double click on the drive letter that represents your cd/dvd drive.
5. look for setup.exe file. then double click
6. installation window will prompt. from here just follow the instructions on the window that will appear.
hope this helps.
thank you so much.
Rhomel V. Datuin
ISD- Verizonbusiness
Jun 06, 2009 | Toshiba Computers & Internet
Install microsoft publisher
put the disc in your disc drive and follow the instructions
*when you get to the screen asking if the installation is standard or custom, click on standard, don't check anything that is not clicked on if you don't have installed on your PC*
Apr 29, 2009 | Computers & Internet
Printer problem
Hi again,
I am sure you got a disc with you when you purchased this printer.Use that disc to install the drivers.But before that i want you to uninstall your previous drivers.To do that go to START>CONTROL PANEL>ADD/REMOVE PROGRAMS and then you will get a list of programs now in that list look for Hp printer driver,then just click on that and click remove.Follow the on screen instructions and the un-installation part will be done.Now all you have to do is install the drivers from your cd again.So just insert the disc,follow the on screen instructions and voila your problem will be solved.
Please don't forget to accept the premium solution as fixya.
Aug 02, 2008 | Office Equipment & Supplies
Installing software for new canon digital camera
Apparently Windows Vista does not require the software and worked without installing it. Regards Trish
Jul 28, 2008 | Canon COLOR IMAGE SCANNER
Canon MF5550 printer driver for Windows Vista
I just found this solution TODAY! After trying for a whole year to fix this thing... It was right at my face the whole time!!!!
1) Uninstall your old Canon MF5550 driver.
2) Reboot your computer
3) Download the Canon MF5550 driver Windows XP version.
4) Open your Vista Control Panel, then click on PROGRAMS (not on Uninstall or something else...)
5) bellow "Programs & Features", click on "use an older program with this version of Windows". Follow the wizard.
6) Locate the program manually. (If you need to search the folder where you downloaded your Canon driver, just go to search file on C. It will probably download on your desktop or Downloads)
7) Open the MF5550 Folder where you downloaded the driver, and click on the setup.exe file.
8) Choose on the next screen Windows XP
9) If you need to change the display settings, go ahead. But I didn't change anything. I just clicked NEXT.
10) Fill in the box: RUN THIS PROGRAM AS AN ADMINISTRATOR and click NEXT.
11) Click Next again and let Windows Vista do its job.
12) If it worked... just click yes and finish. If it didn't, click NO and run it again.
Let me know if this worked for you!!!! I know I've looked everywhere for this solution...
email me at
Apr 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Micro Innovations MCNIC50C Webcam Logo
46 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
