Question about Orion STV2763 27" TV
Sansui DFTV275 Started with white thin lines on the top of tv now the have moved about four inches down , the lines are staying together they just moved
    Genius:
  • Orion Master
  • 1,689 Answers
It is very common in many sets of this type that the electrolytic capacitors in the vertical deflection amp section start to go high in their ESR values.
An experienced TV tech can determine the defective capacitors and change them for you.
Jerry G.
Posted on Jul 12, 2008
Is a Sansui DFTV275 an HD TV?
Is it possible that you typed the model # wrong? I can't find anything for that midel. If it has a hdmi port chances are it is 720p which would be hdtv. If not then it is most likely a standard 480p t.v.
Aug 25, 2014 | Sansui D 27" TV275 TV
Hi there My Sansui TV screen started showing thin white horizontal lines across the top of the screen. All of a sudden the screen starts condensing the picture into fine lines across the middle of the...
It is an indication that you have a problem on the vertical section on the main board. The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
Jan 07, 2011 | Sansui TVS2750 27"
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
I have a 27 inch sansui television. It is about 5 years old and white lines have started to appear at the top of the screen. They are kind of annoying. Does anyone know what that is.
If your TV has a picture tube rather than an LCD display, you have a problem with the vertical circuit
(the circuit that "paints" the picture from top to bottom). Usually a capacitor in this circuit will open up causing this type of problem.
Stargazer
Jan 04, 2010 | Sansui 27" TV
I want to set up my sony vaio (vgn-bx567b) vga external display port to my sansui dft275 27" tv
if the tv has the correct input just plug it in and switch the tv input. if thers no input its kinda tricky,youll get horrible resolution
May 10, 2009 | Sony VAIO VGN-BX567B PC Notebook
Sansui LCT37SD switches off by itself
To anybody that has not been able to solve problems with the sansui lcd tv ,lines ,dots on screen etc after warming up ,pls contact me for the solution to the problem. i have succesfully repaired my lct 37st for next to nothing. garth@cybersmart.co.za
Apr 13, 2009 | Sansui HDLCD3210 32 in. LCD TV
Want to program Dish remote to run sansui tv
  • what kinda off provider!! there is a web sight go under universal remotes and look up the remote you have there should be a code for your remote this should help!!!
Mar 26, 2009 | Sansui D 27" TV275 TV
Insignia 32" TV Thin line across screen 1-2" from top
The original white line problem was caused by improper adjustment of the vertical size for which there is an internal adjustment. The current problem could come from two different sources, one an adjustment again, the other from a capacitor that is losing capacitance and gaining losses; = sick.
If you are fortunate enough to have a surviving TV repair in your area, none of these problems is expensive to find or correct.
Don't be surprised to find the only TV shop operating out of a messy garage since those of us doing this kind of service are dying off and the price one can charge for labor has shrunken to the point that a real business address is too expensive to have.
Jan 03, 2009 | Televison & Video
Sansui dftv275 Remote Control
http://www.sansui.newremotecontrol.com/catalog_item.php?catnum=07640KL030 click here to visit the Sansui webite, this is the model you are looking for.
May 17, 2008 | Sansui D 27" TV275 TV
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
Orion STV2763 27" TV Logo
85 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
