Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
3 blinking lights, no video and audio
Sir,
I have read one of your repsonse to the above problem, where do you send the board for repair ?
thanks
Gino
  • Panasonic Master
  • 8,617 Answers
Contact this link, leave a email stating your model number and let them know you need a quote for repairing the set with a 3 blink error code, They respond quickly. Here's the link
http://servicemanuals.vstore.ca/
Posted on Jun 25, 2008
How can I clean the lens? The device does nat read the CD.
Disconnetting the plag the CD tray remains open so it has been possible to clean the lens.
The device works very well now.
Thank you,
Gino Cucco
Oct 17, 2009 | Kenwood UD-300 Shelf System
No audio or video but LED blinks 5 times
does the unit start or what?
does the unit start fully and shut off??
BTW what was the blinks pattern??
Jul 01, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Tv wont turn on get audio then tv shuts off timer lite blinking
If TV stays in stand by with audio but no video, then common faults are the ballast board, or a fault on digital board.
If the led stays blinking , and tv turns off then the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Dec 21, 2008 | Mitsubishi WD-62531 Projection Television
Hello Need expert advice on the above problem - status light is constant red- we unplugged power and reset, tv green light comes on and then shuts off when red status light comes on. No picture at all. I...
The 18 code does not exist. To read the code press device/input button and menu button at the same time on the tv. count the LED flashes 1st digit short pause 2nd digit long pause, repeats.
The red status lamp indicates there is no communication between the format board and the DMD board (light engine). The most common problem for this is capacitors on the Format board that require hours of labor and possibly sending the entire electronics package to Mitsubishi if the caps don't do the trick. Expect a very large bill, contact you local Mitsubishi Authorized repair facility about this, DO NOT take a chance on your corner repair shop to know how to accomplish this.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The tv goes on stand by mode by itself. My 57' sony does not turn on but remains in stand by mode. Blinks 9x then stops, then starts all over again. What needs to be done?
9 blink in your Sony KP-57WS500 shows error / problem in Audio section.
1= +19 volts &-19 volts are shorted by any reason on A and B board.
2= IC708 is faulty on A board
3= PS701 & PS702 (fuse) are open on A board.
Above are possible reasons of 9 blinks.
If you have electronics knowledge and have tv repair skills then check as per above info. otherwise I recommend get help of TV tech person or contact nearest Sony service center.
Thank you.
Oct 05, 2008 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
