Question about Hoover Washing Machines
Dont know which way round wires go to drain pump in AB100 hoover washing machine
    President:
  • 1,462 Answers
Only 2 wires and it doesn't matter which way round
Posted on Jun 25, 2008
How to remove the drain pump from my hoover washing machine
bend machine one side locate drain pump remove drain hoses, screws and pump, replaced with a new one
Dec 03, 2014 | Hoover Washing Machines
MY HOOVER HNF7148 WILL NOT DRAIN IVE CHECKED ALL PIPEORIMNK FOR BLOCKAGES AND REPLACE THE DRAIN PUMP,THE PRESSURE SWICH I CAN HEAR CLICK WHEN I BLOW UP THE TUBE.ANY SUGGESTIONS
hello kelvin have you checked the wiring from the harness to the pump make sure the wires have no splits in them use a multimeter to check the wiring hope it helps
regards
shaun
Feb 13, 2011 | Hoover Washing Machines
How to clean water filter?
http://www.washerhelp.co.uk/washing-machine-parts/pumps.html#cl_q4
Most washing machines have a pump filter to protect the pump from obstructions such as coins. The pump filter should be at the front of the washing machine at the bottom left or right. It should be obvious (a square or round flap) but sometimes the filter is hidden behind the front kickstrip panel. A good washing machine filter should have retractable pipe at the side so that you can drain the water into a bowl. In any event, please go to this link above, this is all explained again, and there is even more direct information you need to know, the list is large.
Jun 06, 2010 | Hoover AAA140 Front Load Washer
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Hoover top load washing machine
make sure thers nothing stuck in the pump and the pump is not faulty.somtimes a coin can get stuck in the drain hose causing it to not drain intermittently
Dec 21, 2007 | Hoover HTC243 Top Load Washer
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
