Question about RCA Universal Remote Control
Codes for universal remote - RCA Universal Remote Control
  • 10 more comments
  • Anonymous Jul 23, 2008
    I dont have a code search button what do i do?
  • Anonymous Sep 12, 2008
    Hi, im in Guatemala and i lost my code list. The only thing i need is the codes for a Sony, General Electric and a Goldstar TV. So if any one of you have it please help me.
  • Anonymous Dec 17, 2008
    I need to program a rca universal remote for my philco dvd player
  • Anonymous Dec 18, 2008
    i have an rca 4 way universal remote and need codes for a vizio flat screen tv
  • Anonymous Dec 27, 2008
    i have a RCA universal remote and i can't find a code to match my GPX dvd player can you help me?
  • Anonymous Dec 30, 2008
    i hav e a rca rcr 3273 uni remote i dont have the code for a sun gale dvd player
  • Anonymous Feb 21, 2009
    what are the 4 digit codes for sony
  • Anonymous Mar 07, 2009
    i have a direct tv remote and need codes for magnavox, the ones supplied don"t work
  • Anonymous Mar 10, 2009
    I have rca remote rcr3273 need code for sylvania tv SRT2227
  • Anonymous Mar 21, 2009
    I have an Audiovox VE700 TV and remore doesn't work. I also have an RCA Systemlink3 but can't find a code that works
  • Anonymous Mar 29, 2009
    i need the codes to a universal remote but am getting nowhere
  • Anonymous May 03, 2009
    i have a rca 410bl and it wont pick up my hitachi tv
    Sergeant:
  • 260 Answers
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Posted on Jun 25, 2008
How do i program this stupied rca remote control
Posted on Nov 08, 2008
I HAVE A GE UNIVERSAL REMOTE ... I NEED A CODE FOR A HITACHI TV??
Posted on Nov 24, 2008
I need code in 1001-1078
Posted on Sep 15, 2008
I ahve a older r c a universal romet and for got hoe to program it i have the codes just for got hoe to program
Posted on Jan 16, 2010
I need codes for the Really big universal remote for my big screen Hitachi
Posted on Sep 17, 2009
I have a Vizio tv and my universal remote needed a 3 digit code. Try 502 It worked for me perfectly
Posted on Jan 02, 2009
I have a rca universal guideplus gemstar remote and dont have the codes to set up my toshiba dvd player
Posted on Oct 14, 2008
I HAVE A 3-1 REMOTE AND FORGOT THE CODE PLEASE HELP.
Posted on Mar 23, 2009
  • 3 more comments
  • MSALIB Mar 23, 2009
    I have a 3in1 remote controle and forgot the code for my toshibe tv ple
    I HAVE A 3-1 REMOTE AND FORGOT THE CODE for tos PLEASE HELP
    i hav
    toshiba
What is the universal remote code because I lost my remote to my
Quincy universal remote codes links below, just look and find yours in the links.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
http://www.humaxdigital.com/rcu/rcucodelist_mdb1.3_gb.pdf
Codes for Universal Remotes
4 Digit Universal Remote Codes For TV Codes For Universal Remotes
Apr 25, 2016 | Universal Televison & Video
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
I have an HD access modeled ETA 1030 converter box and I have a Time Warner Cable universal remotes I was trying to see if there was a code for that?
      Universal Remote Control Code Finder. Philipsuniversal remote controls can operate audio and video devices of almost any brand. For each of your audio/video devices, you have to enter a Device Code in the universal remote control.
      www.urc.philips.com/
    Feedback
    GE Universal Remote Codes ' Jasco
    https://jascoproducts.com/support/ge-universal-remote-codes
    Note: If your remote was purchased before January 2006 Click Here for the 3-digitremote code list. Program your GE Universal Remote using the correct code list and instructions.
    Universal Remote Control Codes
    www.remotecodelist.com/
Feb 05, 2016 | Universal Televison & Video
I have a broksonic TV. and I need the code to a lm-1079 TV remote
Universal Remote Control Universal Remote lm-1079 Need ...
tv.manualsonline.com/...remote-control/...remote/need-codes-for-univers...
May 9, 2014 - Need codes for universal remote model number lm-1079. Asked by paula young on ... 1 how to set code for tv from lm_1079. Was this answer ...Missing: broksonic
Universal Remote Control Product Support ' ManualsOnline ...
tv.manualsonline.com/support/universal-remote-control/
Need codes for universal remote model number lm-10. Universal Remote ... UniversalRemote Control Universal Remote ECCO LCD 24?€? Tv. 0 Solutions ...
Universal Remote Control Codes - iWave Super-Sized
Dec 30, 2015 | Televison & Video
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Can a universal remote work on my sansui sv2002
Universal remote codes for Sansui TV are: 0135 0310 Just buy one universal remote control, which have these setup codes for Sansui Brand TVs with its code list. Code list will be attached with the remote control packing.
Oct 26, 2012 | Televison & Video
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
7,061 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
