Question about Maxtor Hard Drive
Problem swapping hard drive
I built a new computer and wanted to put the HD from my old system into it. I have all the right connections, but the hard drive gives disk read failiure messages and S.M.A.R.T. errors in the new system.
When I put the drive back in my old pc it works like always.
  • MAW74656 Jun 25, 2008
    Greeeeaaaaattttttt.
    I was hoping not to have to reinstall windows and stuff. I better get a new drive ASAP, I don't want to lose my data. Is a drive with smart errors reparable? or is it garbage?
    Is it possible that the new round IDE cable I bought is bad and that is what's causing these errors?
  • 298 Answers
Smart errors are telling you the drive you are inserting will fail soon. It has recorded errors that indicate that drive is no longer usable. The drive still may work right now. But there is no telling when it will bite the dust. It could be 2 hours, it could be 2 months. I would trash the drive with smart errors.
Posted on Jun 25, 2008
  • 1 more comment
  • F1forHelp Jun 25, 2008
    You cannot repair a drive that has smart errors. The cable has nothing to do with smart errors. Smart errors are mechanical problems inside of the drive.
    Ahh...I see why your confused. Your old computer either does not have smart error detecting capability when you start up or it is not activated. You can activate it in the bios IF it has that option.
    That is why you havent noticed this problem in your old computer before.
    You can verify exactly what smart error is detected by downloading Speedfan and checking the harddrive status option.
    http://www.almico.com/speedfan.php
Won't boot from SATA Hard Drive
Specs say it comes with a SATA hard drive. Go into the BIOS and check that it is booting to the HD as opposed to the DVD ROM? If it is, then remove the case and check the connections to the hard drive and from the hard drive to the motherboard. If they are all OK, then you need to swap out the hard drive for a new one, or at least get it tested on a system known to work. You may be able to recover data by putting the old HD into a hard disk enclosure.
You can also try booting to your windows media disk and run scandisk to the SATA HD.
Acer Aspire AMD A6 500GB HDD 4GB DDR3 Desktop PC
Nov 11, 2015 | Acer Recertified - Aspire X AX1470-UR308...
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
No boot device available - strike F1 to retry boot, F2 for setup utility after getting the blue screen of death
Your PC is telling you that it cannot recognize your Hard Drive. You need to order a new Hard Drive. They are very cheap. Then you will need to re-install Windows. All of your data may be lost, but you can bring your Hard Drive to a data recovery center or PC Store to see if the data can be retrieved.
Hard Drive is probably dead so you will need to purchase a new one.
Sorry and Good Luck.
Oct 15, 2009 | Dell Dimension 8400 PC Desktop
I want to pull info off a hard drive & put onto a disc.
If your new computer doesn't accommodate the drive then you will need a three and a half inch hard drive enclosure to put the hard dive in from the other computer.
You will have to look at the drive to work out which type enclosure you will need.
It will either be a SATA connection like this >>>>
Or a IDE/ATA connection like this >>>>
If you compare the connections on these examples you will one has plastic connections and one has brass pin connections.
As soon as you know which type of drive you have you can then proceed to purchase an enclosure.
When you have got the correct enclosure all you have to do is install the drive and connect it your new computer.
You will be able to access the drive, copy your data and use the drive as an external hard drive.
Regards.
Sep 22, 2009 | Dell Dimension E310 PC Desktop
I have down loaded all my memory from my old computer on to a wd external hard drive.I now want to put all i have on the HD on to my new computer.but the computer dont reconise the hd when i connect...
it is may be due to the usb device driver problem. go to the device manager and see that the usb mass storage driver is installed in ur system . if not then install it from ur motherboard cd and then plug it and certainly it will work.
Sep 05, 2009 | Computers & Internet
Want to install new WD hard drive into my old computer
You say you see data on disks on your existing system, yet they appear blank when trying to install? Please try to dig a little deeper and find your setup file. Data wouldn't disappear unless your running NTFS now and the disks are FAT.
Jun 23, 2009 | Sony VAIO PCV-RX450DS PC Desktop
New hard drive on old e-machine. "No operating sys"
First of all did you install an operating system on your HD like windows or linux, copied doesn't work really good, take out the old HD for the new one and install the operating system. You can always afterward copy your old data on the new one
To enter into Bios puch "del" "F2" "F5" and "F8" simultanously (depend on the bios) when in bios go in BOOT menu with left or right arrow. then go down on the new hard drive and put it on top of the list, usully with F5 and F6 (how to use the menu is describe on the right), then press F10 and "Y" (yes) to accept the modification...
good luck
Dec 19, 2008 | E-Machines eMachines T3830 PC Desktop
I PLUG IN A BRAND NEW WESTINGH. HARD DRIVER 160 GB AND COMPUTER S
did you configure the 160GB hard drive as second???
there is a shorting pin between the ribbem cable and the power cable.
take a look on the hard drive, there should have adiagram shows where the shorting pin need to go to make it as secondary drive.
install the hard drive as secondary drive.
if you want the drive to be the primary. you nee to install the operating system on it.
with out operating system the machine will boot up in to DOS only, and a error message telling you the drive has no loader.
Nov 12, 2008 | Dell Inspiron 2200 Notebook
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
Transferring an internal hard drive to another computer
There are several ways but the easiest would be to use an external USB interface such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the IDE connections to your old hard drive as well as a USB cord to your new PC's USB port. This is of course assuming that all you would want is access to the files/data in the old hard drive.
If your plan is to use the old hard drive as the master (meaning you want to boot from it and use your old OS with its settings on the new PC), chances are you would need to reinstall/repair the old OS since it would not run in the new PC.
If you want to install the old HD as a permanent device inside the new PC, you would need an IDE connector and install the old HD as a secondary master/slave.
If you just need to copy/move files from the old HD to the new PC, the initial method would be your best bet. The interface can be borrowed for a one time use.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 12, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
63 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
