Question about Canon imageRUNNER 2016i All-In-One Laser Printer
Trouble with two-sided button
I have no other problem except tryin to figure out how to set the features on my Canon image runner2016 copier machine. I am tryin to figure how to use the "two-sided button" on the machine instead of having to do it the long way. Can you please tell me how setup that button please
Thank You
  • 1,219 Answers
Do you have duplex unit?
If you have do next:
when you press two sided button next appears 2-1 with arrow you must say ok, book type OK, and once again OK.
Scan first side, display sak for next, scan another side and ok
Posted on Mar 01, 2010
I have cannon ir 3300 image runner it shows paper jammed in right side but there is no paper jammed in any side of the machine
Manoj, Try using compressed air to blow dust and debris out of printer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix paper jam Canon iR3300 printer
Home Canon Italia
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-3300
Aug 20, 2016 | Canon Ir 3300 Black & White Copier
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
Feb 25, 2015 | Canon ImageRunner 4570 | IR4570 |
My copier keeps changing it's image quality from ''text'' to ''photo'' when my copier comes out of energy saver mode. How can I get the copier to stay in ''text'' mode and not revert to ''photo'' mode...
I am not completely up on all the Canon machines, but they tend to do thing the same.
If you have you manual handy, look under user programmable features, these types of settings are usually set by the user of the machine. You should be able to set print mode default.
Hope this is of some help
Ed
Apr 30, 2009 | Canon Office Equipment & Supplies
Dont have manual and need to set up scanning for cannon scaner
You can download operators manuals from the Canon website at www.usa.canon.com...The websit can be difficult to navigate and Canon is not very helpful.Good Luck
Mar 26, 2009 | Office Equipment & Supplies
How to remove 4 cassette unit from canon machine IR 400
THIS WILL BE SOFTWARE SETTING ON THE CONTROL PANAL
CANON IMAGE RUNNER 400S COPIER USERS GUIDE
OR
CANON RUNNER 400S SERVICE MANAUL DRIVERS
OR
WWW.CANONUSA.COM/COPIERS
ROD
Feb 09, 2009 | Canon imageRUNNER 400S Copier
We just received some used Canon Image runner 1310 copier/printer and I not have it hooked up to my computer. It is printing just a little off....it slants to one side. Any idea's why?
hi, wel now that you have two questions i still working on your first :P
this copier may only take paper from two diferent trays.
one is named the multi-purpose tray an dthe other just the cassette.
so i gathered you want to print using the MP tray, right? to copy from the bypass (or MP) tray, just choose it using the paper select button (take a look at the panel, there's a button that actually says 'paper select') . now if you want to print from it, go to your printer settings and change the default paper source to the mp tray.
about the other problem im still trying to figure out your problem.
Jan 28, 2009 | Canon imageRUNNER 1310 Printer
Printer does not print automatically. It prints manually
It may need a firmware update, new software, Also check that your drawer sizes are set right. If so you need a canon tech to visit.
Jan 10, 2009 | Canon USA - COPIERS - ImageRUNNER 2010F...
Faxing with the Canon 3570 Image Runner
On the copier display screen is their a tab that says "send"? If not then you do not have the fax option installed. If you have the machine on your network, find out the IP address assigned to the machine and enter the IP address in the address bar of your Internet Explorer browser to access the machine settings from your PC. If you have a fax option you should be able to set it up from there.
Printdoctor
Dec 17, 2008 | Canon imageRUNNER 3570 Copier
Canon powershot A410 (postcard Date imprint Mode)
To turn on the camera simply press the on/off button on the top of the camera.
to view information about when the photo was taken ect. press "disp" button, when your camera is in the display setting (blue triangle).
Aug 19, 2008 | Canon PowerShot A410 Digital Camera
For Canon IRC3200N
1st off, you don't mention if your network sending has been set up, so I'm going to assume that it is. To scan both sides of the page is relatively easy. after you've selected the destination where it should be sent to, on the display there should be a button marked "Two-sided original". simply press this button and choose "book type" and press OK and the green start button.
I'm using a later version of that model, so the button may not be on your display. if it isn't try looking inside scan settings or send settings. Don't be affraid to play with the options available on the screen, they're not permanent, so if you activate a setting that you don't want, you can clear it by pressing the yellow button with the two lines on it.
Also, you need to keep in mind that if you do manage to send double-sided, the image at the computer will appear as two single-sided sheets. to print them double sided you will have to select that option during printing.
If your network send feature has not been set up, I would suggest that you either get somebody familiar with the product, like a canon tachnician, or even clued up I.T. technician to set it up for you.
Jul 21, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER  2016i All-In-One Laser Printer Logo
35 people viewed this question
old marine
old marine
