FixYa.com
Tags:
Garmin StreetPilot c550 GPS Receiver
Screen scratch
posted by javas67 on Jun 25, 2008
Awfull scratch on the screen, can I get to open and replace it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 25, 2008
Not Rated (0)
fidoliedo
Rank:Guru Guru
Rating: 87%, 41 votes
Taking apart the unit is quite easy and replacing it should not be a problem if you are technically incline. Pry of the face by lifting just under the Garmin name, remove the 4 screws that secure the face, gently pull apart keeping note of the antenna and it's orientation which is located on the back top of the case. Gently pull the battery/speaker plug to allow yourself more room to work. Remove the three screws that secure the main board to the face (silver). Gently remove ribbon cable connected at the top to free the face screen. You will need to replace the whole screen as this is one unit.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these GPS Devices problems?
my garmin will not load the...
My garmin C550 will start and... Answer This...
downloading a POI Loader for my...
I was looking in the manual of... Answer This...
wont turn on
gamin c550 is not turning on... Answer This...
Registation ~ uploading new...
I just purchased this... Answer This...
Map update
When I bought my Garmin all USA... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
