Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune screen replaced... buttons not working except 'down'
My Zune will charge and everything, BUT, the only button that works is the down button.
My dad took it apart and installed the new screen himself.
Im pretty sure he's stumped on what to do with it from here.
Help would be great.
  • 8,596 Answers
Take apart = bad; the hold/lock button was probably engaged - unlock it per the manual
http://www.zune.net/en-us/support/usersguide/default.htm
Posted on Jul 06, 2008
My zune 8 gig won't turn on
find the reset button and use a paperclip to press down on the resset button. only for 10 seconds. if it doesn;t work then do it again and hold it for 30 seconds.if that doesn;t work hold it for a min. if that does;t work its fried.
Nov 15, 2009 | Audio Players & Recorders
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
HELP!!!!! My zune's buttons are not working!!!!!
sir, i think you should replace the buttons even. they dont seem to be wworking in proper condition.
May 28, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30 gb zune is frozen
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
goto step 4 only remove clip for battery wait ten seconds. It worked for me!
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
30gb zune only has black screen
Try these ideas first, except calling for service since it's out of the warranty: http://support.microsoft.com/kb/931912. If this doesn't work then, you'll have to erase all the content on your Zune through the buttons on it and use the Zune software to restore the firmware and getting it to boot again. If this doesn't work, then the hard drive may be bad in the Zune and will need to be replaced. If the hard drive is bad, you'll usually hear a lot of repetitive clicking. I hope this helps.
Dec 09, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune screen is black and won't charge
you could have a bad charging cord and also you can try to turn the hold button on and off that sometimes works
Nov 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Frozen zune 80gig 2nd gen, error 5
One last ditch effort: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
And, yeah, as far as the international replacement - that is how all the manufacturers are - they are not willing to pay the cost to keep their customers. Also, they have no process in place for fulfilling such a request, even if they have offices in both countries (which most of them do). Sad, really.
Jun 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune Won´t turn on
my son's just did this and the reset method worked (press the back button and up and hold both for about 10 seconds until the zune screen appears)
Nov 08, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
59 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
