Question about Whirlpool Washing Machines
My Whirlpool Neptune front-load washing machine is leaking. The bottom of the door has what looks like pink plastic melted on the bottom part and some wide, deep scratches that go all the way to the metal. The gasket was replaced due to mold issues and now, no matter how carefully I load the washer load it rocks like I was washing sneakers.
  • 3,037 Answers
Sounds like the bearing needs to be replaced if it isn't spinning uniformly. How does it spin when empty?
Posted on Jun 25, 2008
Hole in Maytag Neptune front load washer door and flaking or melting of door.
I've owned the same Neptune since 1999 and had this problem happen to me twice, the first time the inside molded plastic door melted through in a circular pattern and had to be replaced. The fact that it was circular indicates that something was rubbing during the high speed spin. That something was a stiff bottomed duffle bag that was rubbing on the plastic door during high speed spin. The washer was full of other clothes that didn't allow the duffle bag enough room in the washer tub, hence it pressed against the plastic door. The second time it happened I got a circular groove melted in, but not through, the plastic door... caused this time by a small child's back pack. I would make sure "rigid" items have enough room to "float" in the tub cavity by not putting in other clothing that over packs the washer.
Oct 15, 2017 | Maytag Neptune Washing Machines
Whirlpool front loading duet ht washing leaking from the bottom of the machine
CHECK THE BELOW FOR SOME DAMAGE OR HOLES. ITS THE PLASTIC BETWEEN THE DOOR AND THE TUBE.
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Our Maytag Neptune Front load Model MAH6700AW seems to alway have a wet or damp spot underneath or in front of the door. Where should I start looking for the leak?
the door has a series of small holes in the front bottom lip of the door gasket these are for drainage if they get clogged the door will drip water clean them and, remember to use HE soap
May 11, 2009 | Maytag Neptune MAH6700A Front Load Washer
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Changed boot but still leaks
Are you sure it is leaking from the boot seal? The water could be leaking from the top or front of the washer and running down along the door. Pull the top off and watch the machine while it fills. Use a torch for better viewing.
Nov 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Look for screws on the top cover, normally behind the machine. Take off the wall plug before handling the thing........
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
