Since the largest matrix you can create on the FX-115ES is a 3X3 matrix, I am not sure it is worth it to do it on a calculator.
There is no command on the calculator that allows you to do it.
You
can use the calculator to evaluate the minors for each element (the
determinant of the matrix that is left when you remove the column and
the row that have that element as intersection).
Here is an example how to calculate the cofactor of the _11 element of a 3X3 matrix.
- I defined a 3x3 matrix called b
- I defined a submatrix by removing the first row and the first column of the b matrix.
- The submatrix is called min11.
- Its determinant is the minor of the _11 element of matrix b.
- The cofactor cof11 of _11 element of matrix b is the product of (-1) to the the power (1+1) and the minor of the _11 element.
- The cofactor is represented by the last result to the right of ->cof11, that means b22*b33-b23*b32. The cofactor is a number.
- For additional information refer to your algebra book.
Note: The power of -1 that multiplies the minor of an element is
(-1)^(row number + column number).
coff11=((-1)^2)*det(min11) =det(min11)
cof12=((-1)^(1+2))* det(min12)=-det(min12)
cof13=((-1)^(1+3))*det(min13)= det(min13)
cof21=((-1)^(1+2))*det(min21)= -det(min21)
etc.
