Question about Canon CanoScan LiDE 25 Flatbed Scanner
Continually scanning Once the scanner is connected, the light bar starts and moves to the end position then jams against the end. I've tried re-installing the software and asked Canon Support for help, both without any result (Canon said to take it to a service centre). I'm using XP, and had the scanner a couple of years without trouble before this started. As the machine is only £39, it's easily replaceable, but I thought I'd see of there was a simple solution first!
  • pb_devon Jul 14, 2008
    Hi The Comp,
    The lock was in the unlock position, and i clicked it back & forth to make sure, so it wouldn't appear to be that. However, it has now started to behave itself so maybe Fixya also solves problems in mysterious ways!
    Thanks for taking the trouble to respond.
    pb
Update...... As a result of moving all my IT equipment, I changed the USB lead, and the problem has gone away! Looks like it was nothing to do with the scanner, but a faulty connection.
Posted on Sep 23, 2008
    Scholar:
  • 111 Answers
Make sure the lock switch is in the unlocked position. The lock switch is on the bottom of the scanner. It sounds like something is preventing the scanning bar from getting to the home position. If the scanner was somehow locked with the scanning head being out of the home position, then the result would be what you describe.
Posted on Jul 09, 2008
Keeps flashing up error and light a b c keep flashing
you either have a paper jam or the scanner module has jammed. open the printer and check the paper path for possible jams. then open the scanner lid and make sure the scanner light bar is in the home position at the end of the scanner deck and not stuck mid path.
Feb 27, 2012 | Canon Office Equipment & Supplies
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
Cant get the scanner software to work
Try reinstalling the software using the drivers from HP.com. If you go to HP.com and type in the model number into their search bar it will usually pull the printer right up. Then select drivers and downloads and find the software using your operating system. Simply download and reinstall the software and it should work just fine.
Mar 01, 2011 | HP Officejet 5610 All-In-One InkJet...
I have properly connected my HP Scanjet 2400 scanner with my system and the appropriate software was successfully installed, the light is blinking and when we try to scan, it tries to start, but it...
sometimes the power management causes the scanner to act up or fail altogether.
Try: Solution: Disable power management on the USB hubBy default, Window XP tries to disable USB port when the HP Scanjet scanner is not in use to save power. The scanner fails to wake up when called. To fix this problem use the steps below:
  1. Click Start , right-click My Computer , then click Properties . The System Properties window will open.
  2. Click the Hardware tab, then Device Manager . The Device Managerwindow will open.
  3. Double-click the Universal Serial Bus controller branch to expand it.
  4. Right-click USB Root Hub , then click Properties . The USB Root Hub Properties window will open.
  5. Click the Power Management tab.
  6. Remove the check from the Allow the computer to turn off this device to save powercheck box.
  7. Click OK , and close USB Root Hub Properties window.
  8. Close any other open windows.
Aug 28, 2010 | HP ScanJet 2400 Flatbed Scanner
Lexmark x4690 scanner jam
Perform a hardware test, instructions on how to do so at http://support.lexmark.com , find your printer model, and then click the how to's tab.
If no solution is found or you cannot print the page call 1-800-332-4120
Mon - Fri: 8 am - 11 pm & Sat: 10 am - 7 pm for lexmark technical support.
Apr 24, 2009 | Dell 924 All-in-One InkJet Printer
Scanner does not scan. It seems to be jammed, stuck.
Thanks for your interest. The problem appears to be in the hardware - so I'll
be visiting the store where it was purchased, to either fix it or replace the scanner.
Regards,
Richard
Dec 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Epson 3490 scanner red light flashing message that printer cannot properly communicate with pc
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
Jul 16, 2008 | Epson Office Equipment & Supplies
CanoScan 5000F - Scanner bar is stuck
hi all;
i fixed it by taking the thing apart, pushing the scanner head (the block that is stuck-- that normally moves) back to the starting position. Make sure its snug at the end, a little bit off and you'll be putting it have to take it apart and back together a second time. There's a mirco swtich in there somewhere, and you need to make sure its pressed...
reconstruct, and hey presto, a working scanner! this also worked for my epson 1250 that got stuck once.
Easy as a section of gateaux.
Oct 04, 2007 | Canon CanoScan D660U Flatbed Scanner
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
114 people viewed this question
old marine
old marine
