Question about Dometic Rooftop RV Air Conditioner
Dou therm ac
Had a problem with my unit feezing up......is that a freon problem?
  • 95 Answers
Could be low freon, could be a bad capasitor, could also be a bad fan motor
Posted on Jun 25, 2008
1986 Duo Therm. What type of Freon would have been used?
the gas used will be stated on the plate attached to the outside unit or the ac cabinet outside
it should be R12, R12A or R132A
Oct 14, 2015 | Heating & Cooling
What is wrong with my RV ac unit ?
Low freon switch prevent the compressor from running when there is not enough freon to carry the oil to lubricate it. There is almost always enough pressure to start it but as soon as it's running low pressure drops and the compressor stops.
Aug 04, 2014 | Dometic 457915 Duo Therm Brisk Air...
Dou therm thermostat
Make and Model of roof top unit please?
Nov 06, 2012 | Dometic Rooftop RV Air Conditioner
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Duo Therm AC Brisk Air 13k btu not blowing cold air
you can buy a saddle valve, this is a valve you screw in. I am assuming you have the correct freon as where you purchased your freon they should sell the saddle valve. Hope this helped
Jul 23, 2010 | Dometic Rooftop RV Air Conditioner
Duo therm air
unfortunatly with the new laws u are unable to unless u are a licenced refrigeration/ac technician
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac unit that blows hot air
sounds like the compressor is not kicking in.
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
Mar 27, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm ac problem
Same problem. I have a 2005 on a Rockwood Roo. Worked fine in October 2009. Not working June 2010. Problem is not a freon leak, compressor went bad. I banged the compressor gently with rubber mallet then with a hammer but that did not work. The fan runs, the compressor runs but gets hot. Also no indication of freon moving through system as everything gets warm from the compressor outward.
Aug 25, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
67 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
