Question about Genius Pensketch 9x12 USB Deep Blue (31100006101)
Where can i get more Pen Tips
I have run out of stylus tips, where can i get more?
  • bagof4grapes Aug 04, 2008
    I have also been unable to find any replacement pen tips. HELP!
  • Anonymous Mar 08, 2009
    I need to get some new tips for my genius pensketch 9x12 - where can I get them?
Hi
Found the Pen--->>>
http://www.geniuseshop.com/index.asp?PageAction=VIEWCATS&Category=2
But NO individual tips
Cheers for Years
Colin
Posted on Jan 13, 2010
Codegen tablet can I print to an epson stylus from the miniature USB port
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Nov 26, 2012 | Codegen Computers & Internet
Hi i would like to know how i can get the gray pointy part of our v smile cyper pocket pen. I have the pen attached to it but i need the pointy part. please reply
If you need to replace the gray pen insert, just go buy a nintendo DS replacement stylus and remove the same gray tip from that (carefully **** the stylus lengthwise about a 1/2" then pry out the stylus tip) and glue it in your CyberPocket pen. It's close enough.
You can also buy a replcament Vsmile controller with writing pad, and use the whole pen. (the ds stylus is, of course, cheaper!)
Sep 30, 2010 | Toys
How do you change the pen tip on a bamboo pen?
I posted this solution for a Toshiba Tablet PC that uses a Wacom tablet pen. I am rather confident that it will give you ideas on how to solve your problem.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip. Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside. Press gently but firmly to make sure it is holding.
Dec 27, 2009 | Wacom (EP130EPE) Digital Pen
Have an issue with gateway m285 stylus. The tip came out and the comp stopped responding to the pen. Is there a way to repair it or do I need a new one?
No I would not repair it. The tip of most stylus are made of a conductive material that will not scratch the screen. But good luck you can get a new one from pretty much anywhere. I myself got one from Walmart that was a Stylus and a pen. Just be careful because you don't want ink on your screen LOL
Hope this helps
Sep 13, 2009 | Gateway M285-E Notebook
I need to change the tip of the stylus
I own a Toshiba Tablet PC that uses a wacom stylus.
Hope it helps.
Aug 17, 2009 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Pen tip replacement for Aiptek Hyperpen pen
It is pretty easy to remove the tip. I have a tip remover but you can just use a pair of tweezers or needle nose pliers. Just attach the tool to the tip and pull it out. You do not have to open the pen or anything else. It seems a little hard to pull it but that is the only way to remove it to change tips. I hope this helps.
Jun 11, 2009 | Aiptek HyperPen 12000U (HYPERPEN12000U)...
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Apr 14, 2009 | Computers & Internet
Stylus pen
Nokia N95 is not coming with Touch screen !
for more information follow this link
http://www.gsmarena.com/nokia_n95-1716.php
Aug 19, 2008 | Nokia N95 Cellular Phone
Problems
The stylus pen works by pressure on the tip. Since the tc1100 uses an active digitizer, as soon as you come within range of the screen, the mouse should move (this is called pen-hover), however, if the tip is stuck upwards it will write or click instead just as if you were touching the screen.
Try carefully pulling out the tip using a needle nose pliers or your fingernails if they're strong, and then reinsert the tip gently. This should un-stick it. If this doesnt work, there may be an internal problem with the stylus.
Jul 26, 2008 | HP DG937A - HP Tablet PC TC1100 Tethered...
'Lag' or Trailing Line
I just did some more experimenting and it seems that if I replace the tip of the pen, it starts to react better, not great, but definitely better.
Again, I'm using an Intuos 3. On the Intuos 2 I was using, if I replaced the tip, it would improve, but I was going through tips every two months or so. That's why I bought the 3, thinking it would be better because I've never experienced this problem with my 3 at home (these problems are all happening at work). I'm not sure which tablet your have or if you have the spare tips that come with it, but that might be your solution.
Also, check your Wacom settings and make sure the "tip double click distance" is set to "Off". That should help a little.
Another forum post suggested not using the stylus stand or holder. It could...not sure that it actually does...damage the stylus tip so that it reacts as if pressure is being applied. My stylus at home is always in the stand and, since it does have this problem, makes me wonder if this is valid....but why chance it...different stands and different stylus.
Good luck and hope this helps!!!
Jun 11, 2008 | Wacom ET-45A STEEL Graphire2...
Genius Pensketch 9x12 USB Deep Blue (31100006101) Logo
207 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
