Question about Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau kg260 gas hob, ring not staying lit, possible thermo-couple gone, request replacement cost / parts please
  • Anonymous Mar 17, 2014
    Induction hob not working gaggenau
  • Anonymous Mar 23, 2014
    wont stay lit
  • 59 Answers
Thats the Stainless Steel model KG260-234CA with SuperQuick electric and Safety Thermocouple ignition, I think they come in pairs RS and LS, for around $27.00 per Pair + tax and SH.
The best place to get them will be SEARS PARTS DIRECT on Line at: http://www.searspartsdirect.com/
Eddie Rentas
Tupper Lake NY.
Posted on Jun 26, 2008
I have acquired a Rosiers hob with 3 gas rings and 1 electric, but 2 of the gas fittings are missing is there any chance of getting new ones . I think the model is the Tologne The rings are the med and...
hello there, the model name does not match any of our documents or any documents online. Please check your unit for the model number to enable us get the parts list to determine the part number. The gas rings are usually available for sale although most of the time gas rings from other makes would fit but lets see if we can get the exact ones for your unit. Please furnish me with the model number.
Hoping to hear from you soon.
Thank you for visiting FixYa.
Aug 06, 2011 | Cooktops
The oven on my gas cooker will light but wont stay lit
Thermo coupling needs changing, unless you are Gas Safe, let someone else repair for you, its a common problem, shouldn't cost much, good luck , the Yeti
May 20, 2009 | Miele 20 in. KM405 Gas Cooktop
Burner/Flame
Hiya .. this could be due to a number of problems...... has the burner ever worked correctly?
Is the behaviour with only one ring?
1. If not... then it could be that the pipework to the hob itself has not been recuced sufficiently enough in pipe diameter to the regulator far enough back ...
2.The regulator is faulty... in which case it can be replaced... however consider the cost of a new regulator and labour to fix it .. against the cost of a whole new hob... which should include a regulator. Is the hob still under warranty... if so use that .. but you will normally have to provide some proof it has been fitted by someone suitably qualified.
3.the regulator may never have been fitted, which is dangerous and bad practice.
Either of these scenarios... please ensure that you use a suitably qualified gas engineeer... I dont wish to be alarmist... but gas leaks and faulty gas appliances do cause unnecessary deaths...and is a silent killer.
Regards Faggly
Mar 26, 2008 | Maytag MGC5430 Gas Cooktop
SPV577x Hob
i think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Feb 19, 2008 | Smeg 27 in. SPV577X.1 Gas Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Gaggenau gas rings
The heat has caused it to be stiff. Just apply steady pressure and it will lift off. Gaggenau is real good about making sure that if a part is screwed down that you can find the screw.
Oct 23, 2007 | Gaggenau 23 in. KG 260 Gas Cooktop
Burners will not light or stay lit
lhs burner - problem is probably thermo-couple. this is a safety device which prevents gas escape if flame blows out. rhs burner - you do not say if it can be lit by a match. if so then it is a problem with the electrode or the wire to it chaffed thro. if can't be lit by a match, then a problem with the gas valve which is unusual not a diy fix unless you are experienced
Apr 11, 2007 | Miele 30 in. KM320G Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Gaggenau 23 in. KG 260 Gas Cooktop Logo
586 people viewed this question
Top Gaggenau Cooktops Experts
Tall Tiger
Tall Tiger
Dave Lammas
Level 1 Expert
Claude Kayser
Claude Kayser
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
