Blower fan runs continually with the thermostat removed or installed. This is a older carrier combined unit with a furnace. Control board installed is a HH84AA 011. Replaced the board with a new board and problem continues. Tried to find a fusible link, with no luck. No power to R and C. 120 v on PR-1 to PR-2 and 27 v at SEC-1 to SEC-2. Any suggestions? Bill
  • excide Jun 25, 2008
    The blower fan continually runs all the time even when the thermostat is not calling. The ac supply is what feeds the control board that the thermostat controls. The blower runs with no control wires attached and the only way you can isolate it is by lifting wires. The ac and heat will not work in this condition. That was not the solution.
  • micksutliff Dec 10, 2008
    I have a day night furnace with the same problem and same control board number HH84AA 011 the BLOWER often stays on but not always, not sure if it's the board or one of the sensors. but sounds like same issue I am having I am going to clean board and replace ic ca3098 from intersil if I can find one!
Your sensor to the fan is stuck in the closed position. This sensor kicks the fan on when a certain temp is reached in the heat chamber. It opens after cool down and apparently is stuck closed.
Posted on Jan 23, 2009
  • epilynn Jan 23, 2009
    actually it sounds like a bad transformer. This board requires 24vac to open the circuit to the blower motor. If no 24vac then it will run constantly. Check from terminal R To C on the board and ensure that you have 24vac if not you need a transformer
    Your transformer is bad this board needs 24vac to open the circuit to blower
I had a similar problem but I changed the transformer and had 24volts to R and C and when I jumped R and G the blower would kick on. When I jumped R and W I heard a click and that was it. I'm leaning to it being a bad board
Posted on Nov 23, 2013
  • 38 Answers
Dear excide,
The blower fan is not controlled by thermostat. The thermostat only cuts off the supply to compressor when the desired temperature is attained.To switch off the fan you have to switch off the supply to ac.
ramesh22
Posted on Jun 25, 2008
  • Ramesh Kumar Jun 26, 2008
    Dear excide.
    I am sorry if my solution did not help you. As I understand the thermostate operate on temperature and it cuts off the supply to the compressor / heaters. The fan runs on mains.
    ramesh22
I am replacing the thermostat with the Ecobee3 lite smart thermostat. The thermostat did not power up. My A/C unit is a Carrier model 40AQ030300BB. Might I have popped a fuse or something?
yes you likely blew the fuse. it is likely a blade style/ similar to one in a car, located on a circuit board inside the blower compartment. BE SURE TO TURN POWER OFF AND LOCATE AND REPLACE WITH SAME THING!!
Nov 11, 2017 | Carrier Heating & Cooling
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
I have a carrier Day & Night a/c - heater unit. the model # 591ANX0480000ACAA, 208/230 volts. my blower fan stays on continuously, even after turning the thermostat off. the condenser fan does not come on...
If the blower fan in the furnace won't turn off, there is a tripped/blown limit. It's a safety. As for your condenser fan it could be a run cap or motor. Do yourself a favor and have a licensed HVAC contractor take a look. Find a NATE certified or ACCA member. You will find a much better more qualified contractor.
Sep 23, 2013 | Carrier Packaged A/c 3 Ton 13 Seer And...
92OO wathermaker furnace. Carrier. Blower on continually blowing cold air
Hello, if the blower can not be turned off at the thermostat and runs continually then the relay on integrated control board is malfunctionimg and must be replaced. If it does turn off at the thermostat but runs all tne time and does not lower the temp then the unit is low on refrigerant.
Jun 25, 2011 | Heating & Cooling
An came on by itself and won't cut off
If your indoor unit is electric and not gas or oil, then your problem is either in the control wiring or a relay. With your circuit breaker OFF: Start by removing the wire on "G" at your control board. If you have an older model, there might be a wire nut connection for your thermostat wires.......disconnect the wire nut with the green wire which is the most commonly colored wire used to control the fan. Tape off the end of the wire to prevent it from shorting......turn the breaker on. If the blower continues to run, you have a problem with a relay. If the unit is heating while the fan is running, you most likely have a stuck heating sequencer. If there is no heat, you most likely have a stuck fan relay.
Here is a video to help you identify heat relays/sequencers and fan relays. Having a stuck fan/blower relay is a fairly common problem. Often, you can gently tap the relay to "free" it and stop the fan. However, once they start "sticking", they will continue to do so.
I hope you find this information to be very helpful to you, moving forward. :-)
Apr 25, 2010 | Ruud UAKA060 Air Conditioner
I have a technical question regarding implementation of my Carrier furnace within my residence. Specifically, the furnance has been installed for 17 years and I have not had any problems with it. I have...
Thats a safety.
The unit senses a failure to ignite, so it goes into safety mode keeping the blower running to prevent overheating and fires. And keeping the inducer motor running to prevent the same, as well as raw gas build up inside the unit.
The newer systems are "smarter" and can detect more specific problems and failures. The older ones simply know that the thing didn't light, so they bring on the fans for safety.
Jan 01, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
The fan in the airhandler wont shut off.
The fan is controlled by a blower timer board located inside the air handler, or on older units it has a relay called (of all things) a blower relay. If these items were at fault I doubt removing the thermostat would cause the blower to go off. if bad causing this problem the blower would continue to run even with thermostat removed.
But it is also controlled by the thermostat.
You mentioned that if you remove the thermostat it cuts off. There are 2 switches on most thermostats.
1 has Cool, Off, Heat, and Emergency Heat (on a heat pump stat)
2 The other switch has On and auto (it is for the fan motor only)
I believe because it stops when you remove the thermostat that the switch on the fan is set to on possibly. It should be on auto-matic. This way the fan motor only come on with cooling or heating. If in the on it stays on all the time. If this is the case just switch to AUTO.
Or the thermostat may be wired wrong. The G terminal is where the fan motor gets instructions from the thermostat. Make sure its on G at the stat and the correct wire at the blower coil is being used for the corresponding wire going from the stat to the blower for G. Don't confues G for green it could be any color. The terminals are not for color but it makes more sence to make them color - letter identified. On the other end soemtimes the wires are not colored the same so look carefully.
Also a whisker of a thermostat wire could be touching inside the thermostat and causeing the motor to run 100%. Look carefully at this and see if it has too long of thermostat wires stickinhg on out under the screws to where they may tough other things.
If neither things stop or show the problem and it deffinately stops when thermostat is removed the thermostat is most likely bad.
If this helps you 1 way to make the repairs your\self or helps you realize you need a technician please rate mne as high as you can.
May 14, 2009 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Goodman a/c blower fan will not shut off
Unhook the thermostat wires on the furnace. If the blower shuts off then your problem is either the thermostat or the thermostat wires. If it contiues to run check you high limit switches next. If all else fails you most likely have a bad blower relay. On most modern furnaces the blower relay is part of the circuit board.
Good luck
Mar 29, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
839 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
