Question about WatchGuard Technologies WATCHGUARD TECH FIREBOX SSL 20 TUNNEL PCK VPN GATEWAY TUNNEL PACK - WG018012 Firewall
Firebox The red light on my firebox won't turn blue , i don't know whats going on? so if you could plz help with this issue. thank you.
My 95 nissan pickup has light issues. I can't seem to figure out what causing the night not to work I have tested the fuse block and all leads into the illumination control switch but don't know where
According to the wiring diagram, you should have two 15amp fuses powering the headlight switch. One wire is red and the other is red white.
Power out of the switch is pink blue for the tail lights, and red with green, blue, black, and yellow for each headlight circuit.
Diagram courtesy of autozone.com
Feb 28, 2013 | Cars & Trucks
PS3 3D TV Display Doesn't turn on 2 red blinking lights
HI, in this video you will find how to fix your Sony 3D Display
https://www.youtube.com/watch?v=OdPGSZnTIPw
Dec 02, 2012 | Sony PlayStation Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Red blinking light on top. copier won't copy?
i don't know about ur problem clearly
plz clr problem tell me?
+8801723019697
Aug 08, 2011 | Xerox 8830 Copier
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
Presonus Firebox doesn't sync up.
1. check the drivers update for you device
This is found at the manufacturers site.
2. See if your device is compatible with the OS (operating system) on your laptop.
3. Check the connecting cable to see if you have a broken wire inside the "strain relief".
The cord at this point will have a puffy part that indicate that there is a broken cable.
Apr 16, 2010 | PreSonus Firebox 6x10 External Sound...
My firebox just seemed to stop connecting. the blue light comes on for a second then goes red on both firewire ports...is it my fire wire card on my pc or the firebox?
IF YOU HAD ANY RECENT UPDATES ON YOUR PC.IT MAY HAVE CHANGED SOME DRIVER SETTINGS. UPDATE YOUR DRIVER ON THE PRESONUS WEBSITE. IT COULD ALSO BE A BAD CABLE.
Jul 10, 2009 | PreSonus 6x10 Firewire Recording Interf...
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
FLM-2011 will not turn on
does anyone have the answer to this problem. it seems like alot of polaroid tv's are doing this. please if anyone knows how to fix the tv and get it to turn back on and not flash red to blue anymore, please let us know.
Jun 28, 2008 | Polaroid FLM-2011 Television
Computers & Internet Logo
69 people viewed this question
Top WatchGuard Technologies Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a WatchGuard Technologies Computer and Internet Expert? Answer questions, earn points and help others
