Question about Miele W1903A Front Load Washer
Kenmore Washer 41729042992
My front load washing machine does everything fine except the final fast spin to get the water out of the clothes. I spoke to the Sears tech and he doesn't have a clue what is wrong.
I have replaced my door lock twice on my kenmore washer modle #417.29042992. if you remove the bottom planel you will see a connector with a red wire and a white wire having down . strip a small piece of wire at both ends and push it into the connector to connect red & white wire this is to check the door lock and will allow you to go into fast spin.
Posted on Jan 01, 2013
    President:
  • 1,294 Answers
Plug off the wall socket. Your motor brushes need to be cleaned or changed.
Posted on Mar 12, 2009
4 Suggested Answers
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
  • 4 Answers
SOURCE: need replacement part for front load machine
Contact Mieleusa at (800) 999-1360.
Posted on Aug 06, 2009
  • 353 Answers
SOURCE: water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Posted on Dec 15, 2009
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 16, 2010 | Kenmore Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Clothes are still soaking wet when load is finished.
Have you tryed replaceing the motor speed control. That is also what makes the machine spin.
Sep 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Miele W1903A Front Load Washer Logo
242 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
