Question about Averatec 3150H Notebook
Model 3150h I can't get the pcmcia slot setup. i installed my pcmcia adapter drivers. Laptop does not beep when card is inserted, pc does not show new hardward in taskbar, light for pc slot does not light up. When trying to manually push push side enable/disable button near slot,nothing happens. Lost as to how to enable and use the pc card slot on unit. Have to wireless connect using USB. Would like to use pcmcia lan to free up my usb connections.
    Scholar:
  • 46 Answers
READ ME FIRST BEFORE TAKING ANY ACTION. BY NOT DOING SO, CAN MAKE YOUR SYSTEM NOT BOOT CORRECTLY.
First thing I would do, is look under Device Manager, to see if the PCMCIA slot is not install correctly. The software driver could be corrupted just like Microcrap. Not sure how to. Very Simple. Here's how.
Right click My Computer, scroll down to properties or select My Computer, then press ALT and Enter at same time. Either way same window pops up.
You will be looking for a Tab on the top that says "Hardware". Below that is a button says "Device Manager"
Looking at the list for "PCMCIA" click the plus sign on the left to expand it. Unless you see a yellow triangle next to it, then it's install correctly. To fix it, you can always clcik on it and on the top there's a icon that says "Uninstall" If/When you click it windows will uninstall the hardware only. There's a icon in the same area:"Scan Hardware Devices" Either Click it or restarting the pc, windows will try to install it again. As long as the software drivers are not uninstall, windows will try to install that device again. Most of the time, it will install the hardware without any action form the user. Sometimes you need to tell it where the files are at. If ALL checks out, then check the PCMCIA card and the slot o the pc. The pins could be bents on the inside. Again if all check out fine, try a different PCMCIA card.
Let me know wat happens
comier957
Posted on Aug 10, 2008
I have just bought a second hand compaq nc 4010 i have read that i can make it wireless using a pcmcia wifi card how do i install it as i have no disc drive on the nc4010?thank you
pcmcia is a card slightly smaller than the antique floppy disc that usually fits in a slot on the side of your laptop your model does have this slot, but personally I would go for a usb hsdpa modem as this provides faster broadband internet.
good luck
Jul 28, 2010 | HP Compaq nc4010 Notebook
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
Can u install afire wire card into a compaq presario c700
Yes, but it needs to be a Firewire PCMCIA card. If you do not have a spare PCMCIA slot then you need to remove the other PCMCIA device so you can insert the Firewire PCMCIA card when you need it.
Oct 20, 2009 | Compaq Presario 700 470024-192 Notebook
My wireless is gone, and does not show up in device manager
If your wireless adapter is not appearing in Device manager open the cover on the bottom of the lap top and make sure the wireless card is properly connected, next look for an external switch that might have been accidentally turned off. If everything is good then you may want to try a new wireless card for the PCMCIA Slot.
Oct 12, 2009 | Acer Aspire 5100 Notebook
Where do I insert the Dynex card?
You insert the dynex pcmcia network card in a pcmcia slot, if your laptop has one.
If you don't find a place you can insert insert the card, that means that probably your laptopt does not have a pcmcia slot; maybe it gas a exopress card slot, smaller and more frequent in recent laptops.
Aug 06, 2009 | Dynex 802.11g Wireless-G Laptop Card
Nec USB 2.0 CardBus on HP Compaq nw9440 with Vista Ultimate
Hi I have a Compaq Presario 919EA with xp operating system and others have a nec pcmcia usb 4-port and when the insert locks the operating system
Feb 01, 2009 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
HP dv6000 and NetGear WG511T
try other PCMCIA slots...actually there 2 of them in every laptop.
Aug 10, 2008 | NetGear WG511T 108 Mbps Wireless 802.11g/b...
Linksys WPC54GS wireless adapter installation issue
It sounds like you may have a band PCMCIA slot. Have you attempted to use any other expansion cards in it to test this theory?
May 10, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
DELL 6400 pc card slot issue
check in device manager via control panel, then click classic view; that the pcmcia card bus controller is present in the list and install the card reader driver if one was supplied, if not then there is no need for a driver and it must be a fault with the pcmcia driver.
Sep 03, 2007 | Dell Inspiron 6400 Notebook
Configuration
You should either install the driver software that came with the card or insert into your PCMCIA slot on the side of your laptop of which windows will then identify as new hardware, then install the driver.
Mar 16, 2007 | 2wire (1000-000005-002) 802.11g/b Wireless...
Averatec 3150H Notebook Logo
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
