Question about Sharp AR-168D Copier
SHARP 168D - Won't print from RDP session
I have a 168D that will print 1 out of 7 times from my RDP session. Ive already tried by doing print directly to the printer and that didn't work.
  • 1 more comment
  • jscheponik Jun 25, 2008
    Oh and yes i updated the drivers and tried to use it as a shared printer on the network and also as a shared through the RDP connection and get the same issue either way.
  • jscheponik Jun 27, 2008
    Yes, every time
    No, its not a firewall issue because it will print once ever 6 or 7 tries
  • Sharp Master
  • 2,794 Answers
Does the printer print directly without an RDP session?
Posted on Jun 27, 2008
  • Tim Babcock
    Tim Babcock Jun 27, 2008
    It might have something to do with your RDP connection. The printer isn't behind a firewall is it?
  • Tim Babcock
    I can tell you as a Sharp technician you are going to have trouble finding support on RDP connections.
    They are unpredictable and they can drop connections. A lot of times it can happen from the way the signal is traveling from your computer to the other computer.
    These copiers are only designed to be used on local area networks. If you need to send documents remotely like that, the best way to do it is to upload them to a shared folder on a server if there is one on the network or to an ftp server. Thats what the Sharp manuals tell you to do.
    It's also a security risk as well sending documents that way which is another reason why Microsoft is pulling the plug on support for that feature.
    Good luck on that.
Sharp AR168D not printing
Look above the shelf where copies come out. If you see a disk about 1.5 to 2" across , it may have been bumped into the "locked" position.
Either turn it 90 degrees or take it out & throw it away.
Oct 02, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Wont print
Ok you say it won't print on the glass or in the adf ?
Does the lamp turn on ?
is the drum seated properly ?
Aug 03, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D will not print
you should change your printer data cable or fix correctly with printer port.
Jul 30, 2009 | Sharp AR-168D Copier
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Sharp 168D printer, scanner
Try downloading new drivers for your computer
using this link
You can get the correct drivers by using AR-168D
Jul 21, 2008 | Sharp AL-1642CS Copier
Sharp AR 168D will not print from PC
Try disabling the print queue. In windows 2000 go to printers, then properties of the canon printer, advanced and select "Print directly on the printer".
Also try printing from another computer and replacing the interface cables.
May 05, 2008 | Sharp AR-168D Copier
Problem with sharp ar168d
If you do not have developer in the machine it will not print. let me know if you have it or not.
Nov 14, 2007 | Sharp AR-M455N Copier
Copier wont print
Your unit is fine. Check the paper setting in your word processor and you will find that you are selecting either: (1) special paper type or (2) special paper size.
Sep 24, 2007 | Sharp AR-168D Copier
Sharp AR-168D Copier Logo
158 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
