Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WS55511 Convergenc
The green lamp seems to be focused two to three inches to the right. It is projecting a green image about 3" to the right of the blue and red lamps. The TV only allows me to move the red and blue lamps.
REPLACE THE CONVERGENCE IC (OR IC'S). A FUN JOB I CHARGE ABOUT 200 FOR.
Posted on Jun 27, 2008
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double image on picture model # ws55511
*Screen Looks 3-D
*Colors wont align
Jun 24, 2009 | Mitsubishi WS-55511 55" Rear Projection...
PROJECTION TV COLORS DISTORTED
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Dec 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
