Question about Dell OptiPlex GX280 PC Desktop
Flickering amber power light
On startup for two GX280s, I get an blinking or flickering amber power light but it never actually powers up. I've replaced the power supply on both; no change. I then replaced the motherboard for both; no change. Any suggestions?
  • mlangford Jun 25, 2008
    No fan spinning.
    No sound from hard disk or other indication that it's spinning.
    Unit lost power; prior to that, it booted up normally.
    M/B is Dell P/N Y6281 for Optiplex GX280 SFF. What else might you need re: the m/b?
  • Anonymous Sep 13, 2008
    amber flickering light in pc
  • 3,940 Answers
Normally a bad power supply, but since you have changed that and the motherboard, the front IO panel is next.
Posted on Mar 01, 2009
Chamberlain garage door travel programming
Seems like you either have your photo cells out of alignment or disconnect from operator or a short in the photo cells wires.... make sure the you can see the green LED light on one and a amber/red on the other at the same time with no flashing or flickering. The green represents power supply to units and other color represents alignment, both are a must! so make sure you see them on solid without blinking or flickering.
Oct 09, 2016 | Chamberlain 1/2-HP Whisper Drive Belt...
Dell optiplex mini tower, when turn on the computer amber led lights blink with a , and will not startup
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Apr 25, 2014 | Dell OptiPlex GX520 PC Desktop
Power light flickering
The power light flickering is normal. Most pc power lights flicker to show it is operating. Also your light on you cd rom or dvd rom will flicker when you put a disk in it. Try it now - put a disk into your cd rom [ or dvd rom if you have that] and watch the power light flicker.
Apr 11, 2010 | Dell Dimension 4600 PC Desktop
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
TV will power up
sounds like a bad power pack, blown capacitors most likely.
it can be replaced or the caps can be soldered into the board to replace the bad ones.
Mar 29, 2009 | Akai LCT2715 27 in. LCD Television
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Aug 20, 2008 | Dell OptiPlex GX520 PC Desktop
Flat Battery
Can you run the notebook on the battery at all ?
try this software if you can
http://www.passmark.com/products/batmon.htm
Aug 08, 2008 | Evesham Voyager 5800 Notebook
Power light going to blinking amber
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
Jan 01, 2007 | Videoseven R17PS 17" LCD Monitor
Dell OptiPlex GX280 PC Desktop Logo
549 people viewed this question
Alun Cox
