Question about JVC Televison & Video
JVC cybercam model # gr-dvf21u, reporting error codes E01 through E04. Tape will not eject. History is: Camera brought to me to be cleaned, snowy video. Tested operation of unit w/o tape, camera video clean, crisp. Brief visual inspection of tape transport mechanism showed no foriegn objects, dirt, particles. Inserted tape, tested record/playback. Good clear video on LCD screen. Attempted to eject tape, got error code 04. Put unit to "Off" then play. Got error code 01. I have repeatedley set unit to off, removed battery and waited up to 24 hours before attempting removal of cassette. No luck.
JoeO700
  • 80 Answers
SOURCE: JVC Error Code 02 Safeguard Mode
Brendon, The supply side tape guide can jump out of its track and cause the mechanism to lock up. The load motor is trying to load the tape but cannot, so the load motor driver "times out" and displays the E02 error you're seeing. If you can get to it, try reseating the guide into its track, be careful not to scratch or touch the drum assy located right near the guide track. Good Luck, I hope you can resolve the problem. Joe Weibel customelectronics.org
Posted on Feb 25, 2007
premtech
  • 934 Answers
SOURCE: Mitsubishi vs-50603 removing screen for cleaning
Don,
You were in the right place going at it from the front. After removing the grill the bottom edge of the screen has a series of screws holding the lower edging down. Remove the screws and gently but firmly work the sides of the screen frame up to unlatch the top. When you have the screen/frame in your hand just be careful not to go to far with it - wires attaching the panel controls are still attached and don't have a lot of extra length.
Clean the cans, mirror and reverse area of the lenticular screen and re-assemble.
Bill
Posted on Mar 13, 2008
robotek
  • 1512 Answers
SOURCE: I have had the same
Hi alan
Check the reel brakes. Simple as that
Posted on Apr 16, 2008
  • 521 Answers
SOURCE: I have a Sony Handycam
, giveit a bash canmake it work. Not too hard, just a few sharp smacks on the side.
It's something in the cassette carrier mechanism.
or
it could be the memory stick. you have to remove it, then, again place it properly it may work check it out.
or
The error message is related to one of the reels,
the black rubber one .
open up the cassette compartment, and the black rubber thing
comes out .... you put it back and cam would work again,
The reason for the alarm is because the "s-reel" is not fit in
same location. There must be a "locker" for it, put on top of
the pin, which apparently have fallen off my cam.
you can use the bis pen .you break the BIC pen, and the ink-pipe had exactly
the same dimension as the silver pin (approx 1.5 mills)
you cut it to a good length (not sticking out), put the black reel
in place again, and the BIC-pipe as a "new" lock on the pin.
Posted on Aug 11, 2008
mosesclive
  • 191 Answers
SOURCE: Have a Sharp VCR player/recorder
The sensor for the tape deck has gone bad need to replace it.
Posted on Aug 20, 2008
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Camera gives message E04. What can I do?
Sounds crazy, but It worked for me. I open up the tape door, ejected the tape. lightly squeezed the two long sides of the piece that hold the tape in place. I placed the tape back in. The tape fit slightly more snug in the cassette holder.
This worked for me.
Feb 20, 2009 | JVC GR-DVF31U Digital Cybercam GRDVF31U...
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Jun 08, 2007 | JVC Cybercam GR-DVL820 Mini DV Digital...
Televison & Video Logo
131 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
