I put a new EIDE hard drive in my Gatway Computer. And now it doesn't find the hard drive.
If it was an older computer, maybe it could take only an IDE hard drive.
Posted on Jul 11, 2008
  • Bruce Fraser Jul 11, 2008
    Sorry, bad answer.
    "IDE" and "EIDE" are virtually synonymous, at least for the last 15 years or so.
    - Bruce.
Try to go on the cmos setup then choose the auto detect then press f10 and pres Y enter.
Posted on Jun 25, 2008
My new Western Digital Desktop PATA EIDE 3.5 Inch Internal 250GB Hard Drive only shows 127GB on My Computer. I am running XP SP3 with IDE Connectors. Is the Mother Board too old to handle that many...
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Aug 12, 2012 | Western Digital Caviar SE 250GB 7200rpm...
Doesn't appear
internal or external hard drive ? laptop or desktop ??
check all leads from motherboard to hard drive eide/sata including electrical extensions make sure
they have good connections and are dust free if its a 40 pin flat ribbon type eide this will be the first to fail even something as small as a fauly eletrical fan or the fans electical lead can cause this problem or
it might be a driver issue
click start control panel administrative tools computer management device manager
scroll throughallof your devicesif you see a yellow question/exclamation mark ? ! or a red X
a new driver will need to be installed
rightclick on the device select update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps you
Sep 27, 2011 | Toshiba Computers & Internet
Hard drive cant be accessed.
Hi welcome to Fixya, there are more than one reasons why the hard drive cannot be access. First you should make sure the hard drive is properly connected, if the problem still exist you should take the hard drive out of the computer and put in into another computer that you know is working. If the computer boot that mean it is the connection in your computer is faulty. If is does not boot that mean the hard drive if faulty and should be replace. Thank you
Jun 03, 2010 | Western Digital Caviar SE16 WD5000AAKB -...
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Feb 22, 2010 | Computers & Internet
Pc will not boot, it can not see hard drive. tried new hard drive but no good. The hard drive works in other computer. the hard drive can not be detected in BIOS.
Try switching the eide ribbons from the CDrom to the hard drive. Sometimes, the computer tries to read the cdrom as the primary and the hard drive as the slave. I generally just leave the CDrom out, place the hard drive in with ribbon and let it register in bios.
Oct 04, 2009 | ASUS A8N-E Motherboard
Need new laptop harddrive
Go to either or and look for the hard drive there. The hard drive will be cheaper going thru either of those places. Also check out cause you can compare prices there. Also go thru google and check out the shopping results of the hard drive your looking for as well.
Lots of places to check and the hard drive will definitely be cheaper then going thru HP.
Jul 06, 2009 | Compaq Computers & Internet
Installing 500 GB EIDE HD in a SONY PCV-RX560
what are the jumper setting on the hard drive. make sure the old one is the master and the new one the slave.
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Power Macintosh G-3 minitower computer Hard Drive Replaced
NO you dont have an operating system yet.....please install windows or some operating system
Nov 23, 2007 | Computers & Internet
New Install
replace your data cables and retry. else check your jumper settings to set as slave on the cdrw and master on the hdd.
Sep 17, 2007 | Asrock K8 Combo-Z Motherboard
Computers & Internet Logo
David Payne
David Payne
