Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring how to wire 2 4ohm kicker l7 15s on a memphis st 1000d amp
  • Anonymous Jan 02, 2009
    i have a l7 8" and a l7 12" want to hook on same amp
    Scholar:
  • 173 Answers
I agree with sicaudio but i would keep kicker with kicker if u need a kicker 1000.1 zx i can get them for $260 brand new i would put 1 zx 1000.1 on each speaker like i did and mine is bangin hard and clear that amp any were else will run u 350 - 799 trust me i checked if u want that hook up e-mail me at brandonday87@yahoo.com i can get kicker l7s for $150 with warenty if u dont want to spend a lot of money try hifonix amps ther a good brand
Posted on Sep 14, 2008
    Scholar:
  • 96 Answers
Provided that the memphis studio series is still 1 ohm stable you would wire each coil of each speaker like this : posive to positive negative to negetive on the speaker using 2 jumper wires then run 1 coil from each subs positive and negative the input on the amp that amp would see a 1 ohm load from both speakers as each speaker would become a 2 ohm load. from experience, memphis does not make an amplifier that is brutal enough on power for L7 15" solos, i have the st 1600 d amp running only 2 dual 4 ohm 10 L5's and it is barely enough power for them. For less money than your 2 subs cost retail I can get you brand new matching 2000 watt true competition rated and proven 1 ohm power and 2 subs that would physically fit in your current box, i would however recommend a very very large box for 2 15" squares. you can email me at sicaudio@msn.com , my advice and system designs are always free even if you do not buy thru me. I am usually 1/3 to 1/2 what retail is with full warranties and i can drop ship anywhere in the U.S.A.
Posted on Jul 26, 2008
I hv a Memphis 1100 watt mono block n a kicker 12" l7 try to get rid of the flutter or hum at low volume tried just about everything suggestions plzzz
I once got a hum from running the rca and power wires side by side, separated em and problem was solved. Could also be something shorting to the frame, bad ground,cracked insulation on rca wires, the gain might be set to high or maybe the amps dying. It could take over a year for an amp to completely die. But you can always pick up an electronic noise eliminator from radio shack for like ten to twenty bucks
Nov 05, 2014 | Car Audio & Video
I need an owners manual for a Memphis 16-ST 1000D
there are no manuals from the company or anywhere on google any more but if you need to know something specific let me know and i'll be more than happy to help you out with it. I installed I.A.S.C.A professional car stereo for a number of years and i am still in the game sort of but i'd be happy to help you out however i can.
Feb 21, 2013 | Audio Players & Recorders
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 kicker l7 wanting to wire to best olm with hifonics 1200 mono
the best way to wire it is @ 1 ohm, but your amp has to be a 1 ohm stable amp. i'll attach some pics for you. this wiring depends on what ohm your subs are.
Option #2
2_2ohmdvc_2ohm.gif Wiring Option #3
2_2ohmdvc_8ohm.gif Option #2
Feb 26, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
How many different ways can you wire a 12 memphis subwoofer
you need conneciton to amp streit from battery terminal but make sure you put an inline fuse in the main wire first for safty
Oct 07, 2009 | Car Audio & Video
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
My amp turns on, power light is on, but overcurrent light also
make sure ground is good then turn gain all the way down turn on deck turn it all the way up then turn it off then back on agian its like a jump start the amp then should work and you can reset all youre levels
Apr 08, 2009 | Car Audio & Video
My amp
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Nov 01, 2008 | Pyle PLMRA420 Car Audio Amplifier
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
302 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
