Question about Gateway 3550GZ Notebook
15 pin connection (left side)
Can someone tell me what the 15 pin female connection is for on the left side of the 3550 GZ is for? Just got the unit & dont know.... thanks for help
  • senior_guapo Jul 04, 2008
    yeah bought it used... hooked a external monitor up to it and it worked. Thanks DOS9
  • 243 Answers
Do you mean on the back left side? If so it is to plug in a monitor.
Posted on Aug 28, 2009
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
Is it possible to use the rgb input on the sd-643hd5 as a computer monitor input? My laptop has a female 15 pin video out which seems compatible with the tv's input except that they are both female...
O don't see why not. They are both female by default, as we don't want VGA pins poking out of the rear of our laptops to catch on stuff.
Don't forget to tell the laptop to switch to external screen.
Hope this helps.
Nov 23, 2010 | Pioneer SD-643HD5 64" Rear Projection...
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
I got 4 ''15 inch kickers 2 5500watt power acoustik mono amps my problem is 2 kickers on the right side hittin hard but the 2 on the left not.i thought the amp on the left was bad so i took the rca of the...
Hello herb31,
It sounds like there is a difference in the signal levels on the inputs to the amps. You did not specify what the RCA's are connected to on the head unit side. If they are connected to a stereo pair of preamp outputs, you may be able to solve the problem by using only the channel with the higher signal and use an RCA "Y" adapter to split it to both amps. If they are connected to a dedicated subwoofer output on the head unit, make sure that the head unit is set for "subwoofer". Some less expensive head units, I know JVC in particular, has only 1 set of line outputs and requires you to go into their "PSM" (Preferred Setting Mode) to set the line output mode and if you select "subwoofer", then allows you to select the low pass frequency.
If you are converting speaker-level outputs through a "line out converter", check both the input and output levels.
Also, if you are splitting an output from the head unit, you still need to connect 2 RCA's to the amp inputs. The signal will be properly split if you use a 1-female to 2-male "Y" adapter. To feed the same signal to both amps, you would need 3 "Y" adapters. Feed the output signal to the female end of the first "Y", and plug the male ends into the other 2 "Y" adapters. Then, the 4 plugs you have left on the ends go into your amp inputs.
Hope this helps.
Apr 24, 2009 | Power Acoustik CLASS D SL-5500D Car Audio...
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/
Left Front -
Right Front + White/
Right Front -
Left Rear + Grey/
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Mar 26, 2009 | Logitech Z-640 Computer Speakers
How to make a 15 pin female sound in cable
Ya, here is a diagram I made of my Acoustimass 10 IV input cable. All you need is a female 15-pin d-type connector and a bunch of speaker cable (also one RCA connector for sub connection). Here's my diagram:
Mar 10, 2009 | Bose Acoustimass 10 III System
Tom Tom 1 Not charging.
I have had the same problem.
after carefully dismantling the unit I resoldered the connections to the power plug.( using a fine tipped soldering iron) I did this on both sides of the pcb.
Although the joints did not look to bad after re soldering and reassembly the unit has performed faultlesly ever since.
As you have to disconnect some sockets and remove pcb,s to do the job properly its best done by someone competent in this sort of work.
One thing to note that caught me out, make sure the lead from the internal antenna is connected as you put the unit back together
Nov 07, 2008 | Tomtom ONE GPS Receiver
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Aug 22, 2006 | Audiovox BA200 Car Subwoofer
Gateway 3550GZ Notebook Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
