I tried changing the language from Spanish to English by hitting Feature *501. It says English but the initializing the mailbox themessage still speaks in Spanish. Is there another trick to switch the mailbox message to English?I tried changing the language from Spanish to English by hitting Feature *501. It says English but the initializing the mailbox themessage still speaks in Spanish. Is there another trick to switch the mailbox message to English?
You can't post conmments that contain an email address.
solution you can change your Spanish to English language. at first you in menu to language setting and change your language. Thank you Send report :[email protected]
1. Select the round Menu/OK button Then > Settings > Language > English . Should be done.
Since it's in Spanish currently, you may have to go to Settings > Language > Others > English. Let me know what happens. If you need further help don't hesitate to ask. Thanks for using FixYa.
Set English language: 1. Menu 2. Down 7 times, Right soft button 3. Down 3 times, Right soft button 4. Down 1 times, Right soft button 5. Down 4 times, Right soft button 6. select language now
Press the "Menu" button and locate the "Settings" (should look like a spanner), press "Ok" or "Select", once it's opened, locate the "phone settings" (it looks like a phone receiver or like a mobile handset) using the up and down key, open it and then the again select the first from the list (that should be theLanguage settings), once it's opened, you'll see the english language written in english as "English", select it [or you can just select "Automatic" if it's default language was "English"]. Now, the language of your mobile will change back to English.
If you need further help, let me know with more details.
All you have to do is start your menu from the begining, in timing advance to the language menu(if possible refer timing with the manual) scroll down and select- Anglais, press ok, there you are.
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
Change the display language from English to Spanish or vice versa using the Language menu. 1. From the main screen, press the Center Select key ( ). 2. Use the Navigation wheel to highlight Settings & Tools and press the Center Select key ( ). (It's the last option) 3. Press Phone Settings, #5 4. Press Language, #4 5. Use the Navigation wheel to select English or Español, and press the Center Select key ( ).
Oh boy that's a real problem. I guess the menu is there but you don't understand it because it's in Spanish.
I don't know this particular phone but thinking logically, there are four things I would consider.
1) Find someone who can speak Spanish, there are lot of people who can.
2) Find someone who has the same phone that is in English and copy the key presses.
3) Use Google language tools to help you interpret the Spanish menu
4) Take you phone to a dealer
