Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
Red ghosting on images that are not closeup
My Sony rear projection is experiencing red ghosting problems. This is very annoying and it seems to be on all images except for when the character is in closeup. I think I've tried all adjustments but I can't find anything to fix it. The TV is about 5 years old but this problem has been present for over a year. Please help.
  • 1 more comment
  • Anonymous Jan 28, 2009
    I have the same problem. I copied the #1 solution and will try to see if that works.
  • fatjamie Apr 01, 2009
    ghosting on all images
  • footloose3 May 11, 2010
    I used the above Solution #1 (service menu) to correct the red ghost problem and was successful. Later I read elsewhere, never to enter the service menu or risk serious harm to your TV. Be careful, but it worked for me.
This model has a badly designed optical block. I've had the TV since 2003 and have had 2 new blocks put in under my 3 year warranty, and they also quit after a while and have the same convergence problems. They finally gave me a check for a new TV as it was costing them too much to fix it. It's too old and too $$ to fix, so just get a new set at this point.
Posted on Feb 14, 2009
1. Power off -- let bulb cool.
2. Display - 5 - VOL+ - Power (in quick sequence) to display service menu.
3. Go into the user menu and set auto revision back to auto.
4. Put an image on the screen that shows the problem. I always found the edges of a 4:3 aspect ratio signal displayed the ghosting very well on my set.
5. Use 2 to scroll through the categories to find D GM TG
6. Use 1 to scroll through items in D GM TG to find V POS D
7. Write down current value.
9. Use 3 and 6 to change the value to minimize the ghosting. You should only need to move it up or down a value or two.
10. Press Mute - Enter to save the changes.
11. Power off and let the bulb cool.
Posted on Aug 11, 2008
  • 84 Answers
Try adjusting image revision in tv menu
Posted on Jul 05, 2008
Sony KP-57WS510 Red Hue to screen.
Misaligned grey scale adjustment. Do a white balance adjustment, after entering its service mode. Contact the authorized service center of any experienced service technician. http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
Jun 15, 2017 | Sony KP-57WS510 57" Rear Projection HDTV
Red horizontal lines on the screen
do these appear around the images on the screen? look like a horizontal ghost around the image. if so you have lost horiz.convergence on the red. you might try a auto convergence setup in the menu on most rear proj. tv's if this dosent work then you need to try and find a shop.
Jun 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Red ghosting
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unusable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Oct 31, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red ghosting on rear projection sony tv year 2002 how to fix
The model number is KP-53HS30, the screen is blurry displayin colors of red green pink
Jun 30, 2008 | Televison & Video
Ghost images on the screen
sounds like the two stk392-560 ic's need to be changed, usually about $400 for the parts and labor
Mar 14, 2008 | Sony KP-51WS510 51" Rear Projection...
Ghost red image
If you are connecting via HDMI, try either getting the firmware upgrade from the Philips website or switching to Component (Red, Green and Blue) cables.
Feb 17, 2008 | Philips 55PP9401 55" Rear Projection...
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
304 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
