Question about Philips GoGear Flash MP3 Player
No longer able to download media onto player
When I connect the player to the USB cable ( which is connected to my PC) the player displays do not disconnect but no data transfer takes place. The PC software doesn't recognise that the player is connected and after disconnecting I have to reset the player so that it can be used. It hasn't always done this only recently.
  • Anonymous Jul 22, 2008
    i am not able to down load music to my mp3
  • 8,596 Answers
Get the firmware upgrade by downloading the clean version of the Device Manager from - open Device Manager and go to Update
If it won't recognze, then force recognition:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jun 27, 2008
Songs not transferred
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :-
Jan 07, 2013 | RCA M6204 Video Mp3 Player With 2.0" Color...
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached:
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
I installed the PC Suite for my LG BL40, but it won't connect via USB and my computer doesn't have a bluetooth device. |Ive tried everything suggested and when I connect choosing Music Sync, it connects bu...
First, syncing is the transfer of data between computer software's that are designed to acquire and share with another entity. The sync function usually is embedded in the computer program. Once the computer recognizes compatible software that has several capabilities including transferring data, a USB connection capacity should be achievable. Usually devices that are designed for data transferability should be capable of acquiring a USB connection either as physical cables or wireless Bluetooth technology. The power to sync is contained in the software program. Once software that has sync capabilities is installed on the computer, any USB cable that is attached to an empty port would display a user message asking for further procedures. For example, USB connections on the computer that has media software's would display device recognizes link requiring data transfer. The solution lies in the software that is relied on for sync capabilities. Acquire Windows Media player, Real One player, or ITunes player as downloadable onto the computer to achieve compatibility.
Important Notes
USB ports are available on all computers as versatile connection links to devices that would require communications. The computers original systems are expected to recognize USB cable connection as manufacturers default. Usually, the computer is likely capable of upgrading several software programs that would least communicate with the USB. For example, the program suit installed has compatibility requirements to perform on the computer as an entity. Also, the program suit requires compatibility with USB connection for another device that would be connected to the computer. Attempt to install media transfer programs that are designed with sync features.
Jan 26, 2011 | Computers & Internet
I need data cable drivers for my M300 samsung mobile phone
If you are looking for drivers for moving, adding/removing pictures or mp3's try this.
Transfer MP3 to M300 without driver
  1. While in standby mode, plug in the USB cable to the handset and connect it to a USB port on your PC
  2. While in standby mode, press the Menu/OK key
  3. Select Tools (9)
  4. Select Mass Storage (1)
  5. Select Connect to PC (1)
  6. The handset should display the message, Connected to PC & Call Disabled
  7. Open Windows Media Player 10 on your PC and select the SYNC option
  8. The left-hand side of the Windows Media Player will display the files on your PC, Check the songs you want to download
  9. Press the Start Sync button on the upper left-hand side of the Windows Media Player
  10. A Synchronization Complete message will appear on the phone when downloading is complete.
  11. To return to standby mode, press the left soft key for Done then select Yes (1)
  12. Disconnect the USB cable from the handset & PC
Transfer Pictures and Video without driver
  1. Insert a microSD memory card into the handsets microSD card slot Connect the USB cable to a USB port on the PC
  2. Insert the remaining end of the USB cable into the handsets power interface connector
  3. If necessary, complete the [Found New Hardware] wizard on the PC (The PC will display [New Device Detected] and a new drive letter will be assigned for the handset)
  4. While in standby mode, press the Menu/OK key
  5. Select Tools (9)
  6. Select Mass Storage (1)
  7. Select Connect to PC (1), if the handset has established an active connection to the PC, the LCD will display [Connected to PC & Call disabled]
  8. Browse to the file(s) location on the PC & copy the file(s)
  9. Open the new drive letter (Removable Disk) for the handsets memory card
  10. Create a folder named DCIM then create a subfolder within the DCIM folder named 100SSMED
  11. Paste the file(s) into the DCIMs 100SSMED folder
  12. When you have copied & pasted all desired content press the left soft key for Done
  13. Select Yes (1)
  14. Disconnect the USB cable from both the PC & handset
  15. You will now be able to view the file(s) from the microSD memory card
Or if you need the driver for other reasons I managed to find a link that works and is free for you. :)
Just Click >>>HERE<<<
Jul 19, 2010 | Samsung SPH-M500 Cellular Phone
Music won't download it shows up on the computer but once it's unplugged from the computer it's no longer there...
Media players have certain folders for holding the data in the player.
Most players (not all) will accept 2 ways of files transfers and depends on the USB connection mode.
Some players switch automatically into the operating connection mode when connecting the USB cable.
Other players can be switched through specific key operation on the player or using the menu in the player.
Consult your manual or use internet support for information about your player's functions. See if you have to install software and maybe updates as well.
1. USB cable connect mode MSC = Mass Storage Class.
Using the explorer in "My Computer", seeing the player as an external flash drive:
When the files are not put into the correct destination folder, the content will not be kept in the memory of the player.
Before disconnecting in MSC mode always go through "safely remove hardware", the icon in the right corner of the computer screen: disconnect the player's flash drive in the icon "safely remove hardware", before pulling out the USB cable.
2. USB cable connect mode MTP = Media Transfer Protocol.
Using a software program like Windows Media Player 10 or 11, the player should be recognized as a media device:
Files must be put in a playlist on the computer first: create a playlist.
After that, synchronizing of the playlist onto the player has to be done.
When needing more help, just add a comment in this thread.
Mar 22, 2010 | Jensen Audio Players & Recorders
Downloading issues
Before you start downloading to your Mp3 media player, you will need a software installation CD..
First install the Cd on a PC, and connect a USB cable from your mp3 to your PC..
Your PC will display information in your mp3 device.
To make it easy first create a folder in your mp3 device when it displays and just copy from your PC to the device ...i think that will work..
If you don't have an installation CD you can download on the net.. thank you..
Feb 11, 2010 | Konaki Digital Media Player
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Download songs
connect your mp4 player to your pc/notebook with the help of the usb cable provided with the same....copy songs from your pc/notebook and paste them into the mp4 player which will open as a memory device...
May 15, 2009 | Element Electronics Zr-Element Digital...
Download onto mp3 player
You may first want to check to see if your player came with software that can aid in this process. You'll also need to know what formats of media your player accepts. For these purposes, we'll assume your player accepts mp3 format media and connects to your PC via USB.
1. Connect the device to a USB connection on your computer.
2. If you're using Windows, your computer should automatically detect the device, probably showing it as a removable hard disk.
3. Double-click the removable USB device that your computer now sees and here you will have to browse to see where your player will accept the media; likely, right here will work.
4. Now, just copy & paste mp3 files from your pc to your media player/removable USB device.
5. When done, safely remove the player from the computer.
Jan 03, 2009 | Microsoft Windows Media Player
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
Windows XP SP1
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Philips GoGear Flash MP3 Player Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
