If your mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network........but restriction code at a free of cost is not possible for your mobile so do not worry about this one get the code at a reasonable cost itself.......... Restriction code for your Nokia 2730 model mobile can be got at Superunlockcodes.com which gives easy instructions to unlock your mobile.
If your Nokia 2690 asks for Restriction code means it locked to network ....You need to Unlock it...You can get the Restriction code from here Prounlocking.com and unlock it simply.....
Your mobile is locked with network provider.so whenever you insert a other network , your mobile asking the restriction code..You can get the restriction code for your mobile from Superunlockcodes.com .It helps to unlock your mobile easily.
Your mobile is locked with network provider.so whenever you insert a other network provider, your mobile asking the restriction code.You can get the restriction code for your mobile at http://www.simpleunlocking.com/ .It helps to unlock your mobile easily.
Phone restricted means your phone is locked to a particular provider and need a restriction code to deactivate or unlock the phone to be able to use any network provider simcard.
you can get your restriction code on this paid service site : CLICK ME
All you have to do is follow this procedure :
1. select manufacturer 2. select model 3. select country 4. select network 5. click Get the available service
If you have the code with you
* Put a non-accepted simcard (insert your new simcard) * a restriction code will be ask then enter the code given by the paid service * click OK * DONE.
If your Nokia phone gives you a message saying "RESTRICTED", shut down
your phone, remove the simcard, power on phone and perform the "CODE
ENTRY" instructions below.
-If your phone doesn't say "RESTRICTED", make sure your phone has a
simcard from any other provider (other the the one the phone is locked
to) and perform the "CODE ENTRY" instructions below.
-If you entered a bad code too many times and get the error "NOT
ALLOWED", then your counter is blocked and only a cable method will
unlock your phone (If the code above does not work the 1st time do not
keep trying it as you only have 3 tries).
CODE ENTRY INSTRUCTIONS
-You will received a code that looks something like this: #pw+454545454567715+1#
-Every digit, symbol, number and letter that you receieved must be
entered without any spaces. Follow the directions below to find put how
to get the # p w and +
P appears after pressing 3 times the button ( * )
W appears after pressing 4 times the button ( * )
+ appears after pressing 2 times the button ( * )
- after entering your unlock code the phone should show "SIM Restriction Off". Youg Nokia is now unlocked.
