Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to share the internet while i use two systems.......
I 've two systems...... i've joined using network cable......... but i can't able to share the internet...... if u know means u can share with me.....
advance thanks....!!!!!!!!!!!!!!!!!!!!!!!!
  • 137 Answers
You need to enable Internet Connection Sharing service.
Posted on Jun 25, 2008
Hello my name is prakash i used window7 in my PC problem is me connect my tablet in my PC via cable and start internet but not open any sites why Please solve my problem Thanks
Hi Prakash, you will probably needs to provide a bit more information of the issue, but from what you are sying it sounds like you will need to turn on Internet Connection Sharing on you PC so your laptop can use the internet connection from your PC. Perhaps better solution will be to get wireless access point and use your tablet via the wireless.
If you have issues have a look at the link i shared.
To enable ICS, on your host computer:
  • Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
  • Right-click the connection that you want to share, and then click Properties.
Using ICS Internet Connection Sharing Windows Help
Feb 03, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
How to connect two computers using a crossover cable.
Hi.
You can use a crossover cable to share files and folders between the two computers.
A crossover cable looks exactly the same as any ethernet cable, but its internal wiring is reversed respect to the regular cables used to connect computers to routers or switches.Crossover cables have the 1st and 3rd wires (counting from left to right) crossed, and the 2nd and 6th wires crossed, thay can be recognised because the word Crossover is printed on top of the cable.
Before proceeding ensure that the cable you are using is a crossover. Crossover wiring isdifferent. By using an ordinary ethernet cable you will not be able to extablish a directconnection between computers.
To use the crossover you will need to disconnect any other cable connection to computer ethernet cards. Naturally both computers must have a wired network adapter installed .
After connecting the crossover, you will need to configure the network connection.
Turn off both computers, connect the crossover (cat5 or cat6) cable, and turn back on computers.
Ensure that all firewallare turned off, and on Vista answer yes to all requests of authorization for the new network.
On both computers go to system properties, and ensure that the two computers have the same workgroup.
Second step is going to Sharing and Security, in system properties, and sharing the files and folder that you want to transfer.
Once the folders are shared you will see in My computer (Computer on Vista) the folder shared from the other computer. Simply copy and paste the files.
You may be asked to restart computer after each step.
If after sharing files and folder you want to share Internet connection, then you will have to assign two IP addresses that are in the same range to the two connected computers.
An IP address is a series of numbers from 1 to 256, in the format XXX.XXX.XXX.XXX . The two IP addresses must share the first three numbers to share the internet connection. In the real case, you can set the IP adresses to 192.168.0.1 and 192.168.0.2.
See also:
Connect two computers using a crossover cable
on May 25, 2010 | Microsoft Windows Vista Ultimate Edition
How to join Vista computer to Windows 7 homegroup computer. They ping each other but they are not accesable.
If other users are unable to access your network shares, especially if they are using older versions of Windows or old 802.11b wireless adapters, their systems might not support 128-bit encryption. Select Enable File Sharing for Devices that Use 40 or 56-bit encryption.
To simplify sharing, you can disable password protected file sharing. To do so, select Turn Off Password Protected Sharing.
Oct 06, 2009 | Microsoft Windows Vista Ultimate Edition
About connectiong two pc.
You can connect the computers with a serial cable, or using hyper terminal. If you have a home network, most windows operating systems will aid you to setup a home network so that you can share information
Jul 09, 2009 | Microsoft Windows Vista Ultimate Edition
Sharing of internet connection
You need to purchase a router and two network cables to connect the computers. If your computers do not have ethernet connections then you need a wireless router and two wireless network adapters for the computer. II recommend the Linksys W300N or similar for the router and the Linksys WUSB300N or similar for the network card. There are very simple set up instruction with the router and cards.
May 23, 2009 | Microsoft Computers & Internet
Configuring clint vista to use shared internet in a LAN
The Internet connection must be shared for you to use it. You probably haven't configured your vista correctly. Try connecting via your internet connection (Networking)
Feb 27, 2009 | Microsoft Windows Vista Home Basic for PC
Internet connection sharing
To share an internet connection, you need to have two network connections, one for the internet connection, and another for your network.
If your DSL has a USB connection, plug it into one of your computers and then then go through the network setup wizard, from there it will walk you through sharing an internet connection.
If all the computers have wireless, you can set up an adhoc network, and share the connection that way.
Honestly, the easiest method would be to go out and buy a router.
Aug 24, 2008 | Microsoft Windows XP Professional With...
Internet sharing problem in Xp network
Not clear exactly what you want to do.
Do you want to share files on your network or just access the internet from all the PC's on your network. Do you have a router?
Regards
Apr 04, 2008 | Microsoft Windows XP Professional
How to share lan 3 pc internet
What network interface do you use? Kindly specify what networking hardware did you have there?
Feb 27, 2008 | Microsoft Windows XP Professional With...
Internet sharing
which internet u r using
Feb 27, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
