Question about Dell 810 All-In-One InkJet Printer
Printer my dell printer is sayin papper jam but there is nothingf stuck in it
  • 36 Answers
Try unplugging the power brick & cable asembly......also unplug the usb cable & then reconnect all the cables.....try reseating the cartridges & thn if nothing wrks......lift the printer about 3 inches & drop it....wat it will do is clear any obstructions.....
Posted on Jun 30, 2008
Papper jam
Try to take out the duplexer at the back of the printer and check if there's any paper left inside the printer/duplexer. Also, check inside the printer if there are any foreign objects blocking the paper path.
You might also want to unplug the power of the printer for about 30 seconds then plug it back in.
Oct 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
It says tacke away papper from huvud fack in swedish. its no papper wher they come if it prints att it shuld. whats the mater it maks mi nervus . cant print enything its stuck one this error message!?...
You have not cleared the entire media path, or you didnot open the door specified by the message to check for jams in this area.Please clear media from the entire path, open the door indicated by theoperator panel message, clear the jam, and close the door and the printer resumesprinting. For further assistance, please contact LexmarkTechnical Support.
Jun 16, 2011 | Lexmark C510 Laser Printer
Printer is showing papper jam
inside might be stuck with piece small paper, or maybe dirty make switch stuck.
Feb 11, 2011 | Office Equipment & Supplies
Papper got stuck . spongy peace 9"x1/2" came out ,
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 04, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Duplex jam 0 - check inside
hey just open the back door of your printer remove the jammed papper...den resart your printer n then print...Robert
Jan 05, 2010 | Dell 1815dn All-In-One Laser Printer
Papper Jamm
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab73
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
PRINTER JAM
look for small, small pice off papper in the printer where pappers pass tru
Sep 29, 2008 | Dell 1720dn Laser Printer
PAPER JAM WONT RESET EVEN AFTER PAPPER WAS REMOVED ON A DELL 924
On the paper jam ,I tried to pull the ink cartridge over to center. It came over a little & then it jammed up.I noticed the ink cartridge lock tab had popped up & jammed it to the right , once I got the tab back in place the code cleared & it works good now.
Aug 24, 2008 | Dell 924 All-in-One InkJet Printer
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
