The noise was coming from inside the refridgerator compartment, upper right hand corner. The only part I can see is up there in the schematic is the temperature control. The noise would occur a couple times a day for anywhere from ~ten seconds to several minutes.
Note that everything was working fine in both the fridge and freezer when the unit was making noise. Now the unit has stopped making the buzzing sound. The freezer still works fine, but the fridge is now longer staying cold. So it does n ot seem to be the compressor or compressor relay.
My guess is the temperature control unit in the refridgerator has died, but I am surprised it would make any noise, especially a buzzing sound that can be heard throughout the house. Does my prognoses sound correct?
Thank you,
David
Comment by d_koon14, posted on Jun 25, 2008
Thank you,
David
In unblocking the vent, I took a cover off in the freezer. As I started clearing away frost, I noticed a lot behind the back panels in the freezer. So I took them off. The coils were completely encased in frost.
After thawing them I realized this must mean the defroster coil is not owrking. Behold, the defroster control is in the upper right hand corner of the regfridgerator, right where the noise and vibration was eminating from.
Comment by d_koon14, posted on Jun 28, 2008
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Comment by tresilla, posted on Jun 25, 2008
Post a New problem for Jenn-Air JCB2388G Side by Side
Email this problem
