Weather king central air conditioner
Sometimes the outside unit, the fan will stop spinning and you can feel the fan motor getting hot and have to shut it off. other times, it seems to be working fine and suddenly realize it is no blowing out cold air anymore. have tried using the reset button, will work fine for a day or so. the unit is only 2 1/2 years old.
do i need a new fan motor, or could it be something else?
    Novelist:
    Champion:
  • 230 Answers
You have done a good job under the circumstances. It could be a bad start/run capacitor as well. It carries a lot of amperage so I suggest hiring a technician to check the capacitor and the motor.
Posted on Jun 25, 2008
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
Want prices on outside unit fan condenser
When I am called to replace a outdoor fan motor I charge $330.I am in las vegas and the charge varies form company to company.The fan motor itself is approx $80 my cost(230v 1 phase condenser fan motor).
Jul 21, 2009 | Weather King 10AJA3001AH Air Conditioner
My a/c system is blowing hot air; outside fan is not engaging
First check for line voltage 240v...if thats good .check for burnt wiring at fan capacitor.if you hear the compressor humming but still no fan you may need a fan motor.. when buying your new motor make sure to match horsepower and r.p.m
Jun 22, 2009 | Weather King 10AJA3601AH Air Conditioner
The outside unit is running, but the inside air handler unit does not work? The blower is not working, but you can hear a clicking noise.
turn the power off to the indoor unit and see if you can spin the fan by hand. the bearings may be locked in the motor. if so you need to replace your blower motor. let me know what you find out
Jun 13, 2009 | Weather King 10AJA2501AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
Central unit freezeup when on
If you are running the unit in the A/C mode with the fan in the automatic position it could be the cause of the freezing of the coil. Try operating it with the fan in the on position and see if the problem goes away. When in the automatic operation the fan shuts off when the cooling unit shuts off and air circulation stops. Hence no defrosting of the cooling cycle in the off cycle. In the evenings when the outside temperature drops after sundown the pressures in the system drop in proportion dropping the temperature of the cooling coil sometimes causing ice formation on the cooling coil.
May 22, 2008 | Weather King 10AJA2501AH Air Conditioner
Buzzing and then no cold air
You need a service tech to check out your system. Your compressor may not be starting which could be the reason for the humming noise and no cold air. Dead snake may not be related to your problem.
May 14, 2008 | Weather King 10AJA2501AH Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
223 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
