Question about Toshiba Satellite A60 Notebook
Toshiba Satellite Pro m40 Will not bootup
When I try to switch it on I hear 4 audible beeps & nothing.
Is this telling me that 4 beeps is a fault code? If so what does it mean?
  • Anonymous Mar 22, 2014
    what does a double beep mean
  • Anonymous Mar 26, 2014
    It comes on no display with 4 beeps then 2 beep beep
    Problem Solver:
  • 5 Answers
Yes. Could be a clue to a hardware issue. There are different manufacturers of BIOS... some differences in what the codes mean.
Is it 4 short beeps or a combination of short and long?
A reference for the codes:
Try removing and re-seating your memory card.
Posted on Jul 05, 2008
Hi, My Toshiba A1350-S4527 is not booting. It's getting stuck at the initial bootup black screen. I tried recovering the last good setting but it didn't work. My Laptop's DVD drive is also not working,...
you could try to do this
make sure laptop is switched off
now hold down the zero key and hit the power on key once
when you hear the beeps release the zero key
Hopefully this should take you into the recovery option !!!
Hope this has helped you
good luck
Mar 25, 2011 | Toshiba Satellite A135-S4527 Notebook
About toshiba m40 motherboard
Toshiba Satellite M40 Specifications (as reviewed):
Intel Pentium-M 760 (2.0Ghz, 533Mhz FSB)
1GB RAM (2x 512MB DDR400)
60GB (ATA 100 5400Rpm, 8mb Cache)
15.4" Widescreen TruBrite' Glossy display (1280x800 native)
NVIDIA GeForce Go 6600 128mb PCI-Express
Intel Pro 2195 a/b/g Wireless
Matshita DVD-RAM UJ-8315 (DVD-RAM, +R / + - RW)
Microsoft Windows XP Professional (SP2)
Toshiba 6.1 Hour Li-Ion Battery (6 cell; 4300mAh)
also see this...
Nov 18, 2010 | Toshiba Computers & Internet
Have a Toshiba Satellite M40 I'm trying to work on for a client and having serious trouble... I have the original restore cd and a legitimate Win xp Pro cd and the machine won't boot off either. It just...
try holding f2 or f10 at boot, right when you turn it on, and hold it in until you get into bios or a boot selection screen. then you need to set the cd drive as the primary, only boot device for the time being
May 21, 2010 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Switch on wireless key on Toshiba Satellite M30,
Try downloading and reinstalling the drivers for the wireless network adapter. If you have the original disk it should have the driver if not you can download it from the Toshiba site.
Jan 07, 2010 | Computers & Internet
I want to change the CPU fan in my Toshiba Satellite M40X
I found an awesome site
I found the service manual for the Toshiba Satellite M40X in PDF format
You want chapter 4 replacing the cooling module.
Nov 10, 2009 | Toshiba Satellite M40-S417TD Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba M55-S1001
4 Beeps means there is a fault with the CPU.
It could be that the fan is faulty and needs replacing, or it coul be that the CPU is dead.
Unless you are technically mined enough to take the machine apart yourself, then your only course of action is to take it to a dealer for repair.
Aug 13, 2008 | Toshiba Satellite A45-S250 Notebook
ATI Graphics driver for Toshiba Satellite laptop
Try this
Jun 03, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite M40 Internal Wireless Card replacement
On the bottom of the laptop there will most likely be 2 panels to remove. One will be the hard drive, the other will be your RAM modules and most likely your wireless card. It'll probably be in the middle. Open this up, your wireless card will have two wires plugged into it that you'll have to unplug. Then on each side there is a tab that you have to click outward, then the card will flip up. Then you can just pull it outward. Do the reverse for installing the new card.
Aug 28, 2007 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite A60 Notebook Logo
438 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
