Calculators
Problem for Calculators
Generic problem for all Calculators
Helps with time - - - - what about date - t...
By BobRoch on Jun 25, 2008
Set time OK - - - press "TM", then enter 4-digit time (not 6), then press "set" recessed button.
But same process doesn't seem to work with date.???
Same Problem
Feb 18, 2009
-   I can't set the date. M+= doesn't work. Any other suggestions.-   tcpetes
Dec 19, 2008
-   How to set Dtae and Time?-   ccollazos
Nov 15, 2008
-   HOW DO YOU SET TIME AND DATE? MODELP23-DHIII-   Guest
Best Solution
posted on Jun 25, 2008
Helpful)
gopi20
Rank: Wiz
Rating: 80%, 276 votes
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Calculators
Questions and Unsolved Problems for Calculators
Answer
The calculator powers on but does nothing else. How can I get it to work? This is a TI 84 Plus... (More)
Answer
How do I convert a decimal integer to a binary equivalent? Changing MODE ([SHIFT] [MENU]) does not... (More)
Answer
I'm receiving the message ERR: DATA TYPE 1:Quit 2:Goto I'm receiving this when I try to do stat in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Calculators:
Top Calculator Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
