Question about Kenmore 98702 Stacked Washer/Dryer
I DID THAT DO I NEED TO TAKE THE MOTOR OUT TO PUT IT ON I NEED HELP
    Genius:
  • 1,122 Answers
Can you refresh me on what your doing,i can't find your first question,thanks-mike
Posted on Jun 25, 2008
  • MIKE major Jun 25, 2008
    I THINK YOUR TRYING TO PUT THE DRYER BELT ON,NO YOU DON'T HAVE TO TAKE THE MOTOR OUT,YOU NEED TO GET THE BELT AROUND THE DRUM AND THAN THE IDLER ARM ROLLER UNDER THE DRUM,THAN PUT ALL BACK TOGETHER,LET ME KNOW-MIKE
I need to wire this motor up to a regular 115v switch . can anyone tell me how to do this
if your motor is worling in 220 Vca 1 phase , for to put at 115Vac, you can not do it. Since you need to buy a new motor for 115vac. Not possible in this type of washer motor, only INdustrial you can do that, change the terminal motor and adjust to 220/115.
However if you have the motor for 115VAC, how you wire for 115Vac.
If you can explain with more details, I can help you. my email:ercupa@netscape.net
Sep 25, 2012 | GE Washer / Washing Machine Motor WH20X52
I have bought the new belt but cant see how it fits on to the machine, when I put it on how I think it shoudl be it seems to big but it is pretty much the same length of the one that came off?
Sounds like you have the motor on top of the machine and the motor has moved. You will need to loosen 1 of the nuts on the motor, put the belt on and lever the motor to create tension on the belt then tighten the nut back up. Hope this helps.
Mar 09, 2011 | Washing Machines
How do you replace the coupler
Remove end caps of consol///remove two screws at the end of consols///flip consol up//unplug lid switch///remove two clamps with screw driver they pry out// washer casing will lean forward and come right off////you will now see the pump and motor remove two clamps of pump//there are two clamps on motor may be screws in those clamps look close///the coupler is there one half on motor one half on gear gearcase I use a socket and small hammer to bang each half on//put in middle section of coupler reverse the teardown to put back togeather....If I helped you Please VOTE..if you need more help please ask good luck
Feb 04, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
KAWS750L Washer; motor runs, no drive to transmission. Have the sides off and looking at motor assembly at bottom. How do you access the broken part between motor and transmission?
That's the drive coupling that is broke you will have to remove the 2 clips that hold the water pump on that has the 2 black hoses going to it then slide the pump straight off the motor shaft. Next you will need to remove the 2 screws going onto the two other clips holding the motor to the transmission then remove the 2 clips and the motor will come off replace the drive coupling with a new one might need a socket and hammer to put new drive coupling ends on make center metal bearing even with motor shat and shaft coming out if the transmission and put the rubber boot on the transmission and replace the motor and clips same order as taking it off hope this helps and good luck.
Jan 06, 2011 | KitchenAid KAWS750L Top Load Washer
Need help on how to put a rotor on a kenmore elite oasis he
Pull clips holding motor in place; 2 screws 1/4" heads. Use screw flat head driver to pry apart motor from trans, pry of "rotor" ( I am assuming you are speaking of the coupling) use 3/4" deep socket to gently put on new parts. Line up and re assemble, in reverse.
Nov 06, 2010 | Washing Machines
Drum rotates and then motor locks up. Burning smell comes from machine with continued operation. Drum rotates free by hand. Drive problem or motor?
replace your belt ... the motor does not smell like burning rubber, the belt will exzude that odor.
Pop the top ... remove the front ... use care with the door switch wires.
the drum will come free of the unit.
Put the new belt over the drum, through the tensioner on the bottom, around the motor pulley.
You will need help ... put the drum back on the wheels inthe back and replace the front ... snap the top down
while it is apart, clean the exhaust system completely
Nov 02, 2009 | LG WM0642H Front Load
Whirlpool Ultimate Care II Washer Model#LSQ9665JQ4
NO. the motor is problably good, you need to replace hte motor coupling, behind the motor, part number 285753. its the machine equivelint to a belt.easy repair, if needed you can search you tube as how to remove and replace
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
Kenmore 98702 Stacked Washer/Dryer Logo
22 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
