Question about Jenn-Air JED8230 Electric Cooktop
Old jennair cooktop
How do I wire from the switch to the fan? what wire g oes where? thanx
  • ddouget Jun 30, 2008
    just got an older jenn air, don't know where all the wires go, do you have a diagrham?
The wiring diagram is pasted on the inside of the panel you remove to get to the wiring. If no wiring diagram The blower operates on 110 volts not 220 So the wire goes from one of the hot sides (Black or red) to the switch controlling the fan to the motor , from the motor to the neutral (white/Bare) wire terminal. Pilot light for fan is attached to the same wires as the motor. If you don't know what you are doing disconnect all wires from the burner switches to the fan motor. This will mean you have to switxh on the fan yourself whenever you need it.
Posted on Jul 07, 2008
How do I replace the switch for a jennair electric cooktop? model jed8430adb. Thanks!
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also at the top of the down draft cavity (the down draft cavity is where the grease guard mesh is)
Nov 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Electric shock from cooktop, didn't trip breaker,
Where did you smell the smell was it from the fan switch. turn the power off and take the screw out of where the fan switch is and check the wires to the switch and the switch itself. sometimes the jennair cooktops have issues with that switch. let me know how it goes
Sep 20, 2009 | Jenn-Air JED8230 Electric Cooktop
I took out an old cooktop which only has the black, white and ground wires. The jennair cooktop with 5 electric elements has black, red, white and ground. how do i connect these together.
sounds like the old one is 110 volts , and the new one is 220 volts. incompatable, as the 220 ones would work, but at half power if you didnt use the red wire. might work fine. omit the red wire and wee what happens
Jun 14, 2009 | Jenn-Air JEC9530 Electric Cooktop
Need a wiring diagram for the burner switch for model c-206b-c
Hello vijay_sin204,
Here is a link for you to view a wiring diagram as well as exploded view with parts list of your cook top. I hope this helps you..
Nov 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Jennaire jed 8430adb Cooktop
you can find the parts breakdown at parts
I looked up the fan switch # for you it is Part # 74009254
it is a big job to replace just remember to turn of breaker.
Oct 31, 2008 | Jenn-Air JED8430 Electric Cooktop
Electrical hookup
no its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Jan 26, 2008 | Jenn-Air JED8430 Electric Cooktop
JennAir Elec Cooktop Problem
The selector knob having lose contact the elements are for full adjument , the wire connection are rust and corroded need to clean terminal of elements.
Jan 04, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
809 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
