Question about Phase Linear UDV9010 Car DVD Player
HAVING PROBLEM WHEN I PUT THE DVD IN I GET A BLUSE SCREEN SAYING ENGAGE E BRAK SEQUENCE HOW DO I BYPASA THAT
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
Reboot with cd
Put the cd in the drive and the system might be set to boot from it automatically.
If not, Put the cd in the drive and watch your screen for which key it says to hit to change the Boot Order or Boot Sequence, when you see the message, hit that key. This is a temporary change only good for the current boot cycle.
If you want to make a permanent change to the boot order or boot sequence, reboot your system and watch the screen for which key it says to hit to enter the Bios or System Setup. When you see the message, hit the key. Tab over to change the boot order or boot sequence. Normally you would make the CD/DvD drive 1st and the Hard Drive 2nd, because if the hard drive fails or has a problem you can always insert the cd and it will boot from it first. Just make sure when you boot that there is no music cd or movie dvd in the drive or you will get a message saying something to the effect of Unbootable device.
May 14, 2012 | Computers & Internet
Screen says engage emergency brake sequence to enjoy video
You are not supposed to watch unless emergency brake is activated. Or trick it into believing that is so. Locate trigger wire on back of unit & run a ground then to a toggle switch then to trigger wire. Turn on switch when you want to watch.That disables that function.
Jun 14, 2010 | Jensen VM9510 Car DVD Player
My vm9510 wont play the dvd with out saying parking and screen blue
You have to connect the park wire of the Jensen to your hand brakes that gets a negative signal everytime you engage it or you can try to put in series the park wire to a switch and any ground. Then read your manual how many times you got to switch it on and off until the picture appears when your dvd is playing. Same thing if you connect it to your parking brakes you got to engage your parking brakes on for 1 or 2 secs then back off then back on again for 1 or 2 secs keep doing this varying the secs till you get a picture. That will be the sequence to turn off that blue screen and on the dvd to watch the movie. Read your manual very carefully it will tell you the same thing but you definitely have to hook up the brake wire or else you will never see the picture. Check the manual for the color of the brake wire or just find the longest wire on the harness and thats usually the brake wire.
Apr 07, 2010 | Jensen VM9510 Car DVD Player
I want to change the region code on my sony slv d281p
I dont know is this work in your brand, but we dont lost nothign whit try it:
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Hope helped.
Oct 29, 2009 | Sony SLV-D281P
I have a pioneer AVH-P4000dvd 2 din in dash dvd player. I hooked it up right, I did not do the by-pass, I hooked it up to the e-brake. When I play a dvd I get audio but no video. I have full control of the...
push in the driving brake. while holding in the brake , engage the parking brake. disengage the parking brake.then repeat this step again. a notice should pop up and you should be fine after that. I put one in a F-350 and had the same problem.
Jun 27, 2009 | Pioneer AVH-P4000DVD Monitor
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
IVA D300 problem
in order to see the movie you have to first push the foot brake,then engage the parking brake, then while continuing to push the foot brake, release and re-engage the parking brake. that should get the movie going.
Sep 11, 2008 | Alpine IVA-D300 Car DVD Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 31, 2008 | Dual XDVD8181 Car Video Player
My phase linear uv7i can't plays dvd's or cd's and the screen is totally blue
caution it´s unlawful to operate a vehicle while video is dispayed in thr drivers viewing area
engage emergency brake sequence to enjoy video???? help help please
Jan 26, 2008 | Phase Linear UDV9010 Car DVD Player
Region code
1. Open the tray
Nov 11, 2007 | Goodmans DVD2100B DVD Player
Phase Linear UDV9010 Car DVD Player Logo
73 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
