Question about HP LaserJet 3030 All-In-One Printer
HP 3030 Please can anyone let me know if this machine can receive faxes at the same time as sending them. If this can be done how do I set this up ?
No, you only have 1 phone(fax) line and it cannot handle 2 calls at the same time.
Posted on Jun 27, 2008
The procedure for how to send the fax from hp laserjet 3030?
Refer here to the Fax Guide for detailed/ Step-by-step instruction for setting up fax on HP 3030
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously if the solution could have been of any help!
CreativeTECH
Dec 16, 2010 | HP LaserJet 3030 All-In-One Printer
I have an HP Lazerjet Model 3030. Recently I have
Here is a link to Hp for your Laserjet 3030. Look under Troubleshooting Fax Codes and Trace Reports. Click on 'Fax send and receive codes'. Scroll down the page to locate each code that you mentioned. I suggest calling your fax number from a cell phone to see if the fax line is clean (doesn't have any noise or static other than the "handshake digital tones") If it does have other NOISE....have the phone company check your fax's phone line for troubles. Let me know.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&prodSeriesId=378056&objectID=c00062808#A5
Nov 18, 2009 | HP LaserJet 3030 All-In-One Printer
Fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
Hp 3030 will not send faxes or receive them
Check the phone line with a regular phone.
Plug phone line into the LINE port.
Feb 01, 2009 | HP LaserJet 3030 All-In-One Printer
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Re; HP LaserJet 3030 Fax -low memory problem
is this plugged directly into the wall by chance, or a power strip?
Jul 28, 2008 | HP LaserJet 3030 All-In-One Printer
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Not receiving faxes
Any electrical disruption, interruption,disconnection can and will reset machine.
If you have ANY KIND of telephone answering machine BEFORE the hp3030, then you have to tell (or command) the answering machine to pick up in 2 or 3 rings. Tell the hp3030 to pick in 4 to 5 rings. I am sure that you know that a fax has a different signal then a regular "talking" signal. If both try to pick up at the same time, u confuse the ' poor little thing '.
Also:: take a look at all the wires going to the fax, telephone, answering and the wall output. Look for bent,cringed,cramped,twisted wires and replace if necessary. They will cause problems.
Mar 27, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
