Question about Dell Wireless Keyboard Optical Mouse w0147
Opening the casing of Dell Wireless receiver to change the battery
Hello FixYa Peoples:
I have a wireless receiver/Interface with the numbers:
| DP/N 0U0754
| FCC ID JNZ201598
| M/N 830822-0000
The battery low light is showing. So I figured that I need to open the case and change the battery. Well, short of breaking the casing this seems hard to do. I can't find a technical manual with instructions on the internet, so I figured I would ask if someone has a clue before the battery fully dies and I must use the brute force method to open the case.
Thank you
  • sanman4733 Jul 19, 2008
    put new battyeris mouse wont work
5 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: how do I open the receiver for my wireless mouse to replace batte
The receiver is plugged into a USB port and doesn't use batteries. The keyboard and mouse use batteries and they need to be replaced ever so ofter. to do so, follow thes instructions.
Normal 0 Are your batteries in the Keyboard and mouse good?
Press the Receiver button (and the lights will start flashing, then if its the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If the MOUSE isn't working, do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Posted on Jan 17, 2009
Demmy
  • 59 Answers
SOURCE: dell wireless mouse/how to open case to install new batteries?
I cant look up the model number you gave. but check out this link. this might help. it contains all the manuals for dell peripherals.
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=6&~cat=1
Posted on Nov 27, 2007
wayneard
  • 1901 Answers
SOURCE: wireless keyboard and mouse not working, battery in receiver?
The receiver has no batteries. It runs off of the USB port. Is the red light on under the mouse? Is there a small connect button on the receiver? Push it. How about on the mouse? Keyboard too? Go ahead and post the model number.
Thanks for using Fixya.
Posted on Sep 17, 2009
firesnake09
  • 2923 Answers
SOURCE: wireless part 830822 shows red light for low battery. What to do?
Change the battery with fresh ones. But if same problem occurs after changing the battery, contact the manufacturer for repair.
Have a great day!
Posted on Sep 28, 2009
HID keyboard (ACER) FCC ID: E8HKBR0355 Model number: KBR0355 stopped suddenly although the keyboard is working, changed battery but not working
i have restarted my PC and as my mouse is working, i make sure the the wireless connector is working i pressed the button at the middle of it to make it blink contentiously and then pressed the button at the bottom of my keyboard, that is it.
Dec 16, 2009 | Acer Wireless WIL-152 91.84R07.152...
Wireless keyboard and mouse not working, battery in receiver?
The receiver should not have a battery. It gets its power from the USB port. Try uninstalling both keyboard and mouse via (Control Panel...Device Manager) and reinstalling them. Sometimes the drivers get corrupted and reinstalling them will fix that. Also there are on/off switches on the mouse and maybe the keyboard. Check that someone hasn't turned them off to save batteries when not in use.
Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Cirsor will not move batteries have been changed
its a small reset button on the bottom of the mouse,you have to push it with a small pointed object to reset it,also get lithium batteries and unplug and reinstall theusb chip.good luck.hope i helped
May 01, 2009 | Computers & Internet
Wireless mouse and keyboard not working
If you have got a USB receiver for the wireless keyboard and mouse, then the solution might be with the receiver. Normally we know that to play a USB thumb drive, we simply plug in and play. But some model of Acer computer require us to press the button on the thumb drive to activate it. The model I had (an Aspire model) set the press button same as the blicking light bulb. So (a) turn on computer, (b) plug in thumb drive receiver (c) press button on the drive, (d) press "contact" button on the mouse and keyboard. That works for me.
Mar 08, 2008 | Acer Wireless WIL-152 91.84R07.152...
Keyboard not responding
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
The springs have come out Dell Logitech wireless mouse
springs came out. anyone have a description of how to re-assemble.
Sep 05, 2007 | Computers & Internet
Dell Wireless Keyboard Optical Mouse w0147 Logo
1,056 people viewed this question
Alun Cox
