Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Fridge does not cool below 40 degrees
I recently purchased a Samsung RS2530BBP and the fridge does not cool below 40 degrees even on the coldest setting - our old fridge was colder on lower settings. The freezer works just fine.
  • Anonymous Aug 30, 2008
    We live in China and bought a Samsung side by side--a big investment for we have a big family.  Shortly after we bought it it made noise, like ice grinding noise; but everything else seemed to be fine.  Then after a little over a year, the temperature of the fridg rose and became unusable.  We have repair people over for a dozen of time--they even took the fridg back to repair for a few times and took weeks before we could get it back each time.  The temperature kept rising and became worthless to keep food.  When we contact the Samsung headquarter, they said they will try to fix it. How many times does it take to fix a broken, flawed designed fridge before it will work?   Warning: DO NOT BUY SAMSUNG.  They care less about what we have to go through, all the spoiled food and headaches.  And for us, it multiples by a dozen times.
  • QUBZ Jan 24, 2009
    My Sumsung refrigerator is not cooling at all. I have tried all solutions I cna find online without success. eg, reduce the temp, unplug and defrost etc
    Please help
    Problem Solver:
  • 9 Answers
This is a common problem and a design fault...
Posted on Sep 06, 2008
The middle part of the freezer and the fridge from my samsung is too hot.
hi there, sounds like you need to clean the back of your fridge, dust maybe blocking your vents, causing poor cooling on your condensor
cheers
Nov 16, 2012 | Samsung RS2530BBP 25 Cu. Ft. Side by Side...
I've had a Samsung fridge for 6-7 years, it's a small/medium fridge/freezer with the freezer at the top (sorry, don;t have the size handy). The freezer works fine, however the fridge no longer makes...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung Refrigerators
Noise coming from the back of my Samsung RS2530bbp refrigerator, fan like noise
if it is a squeeking noise it could be that the bearing on the fan motor is going out, if it is a tapping noise or a fluttering or maybe even a thuding the fan blade is hitting something like papper,mouse,insulation that was taped to the fridge for either sound barrier or temp. control.You will need to pull refrigerator out and use 1/4 or 5/16 nut driver and pull back cover off to determine the cause, be sure to er-install cover for if you do not it will not keep compressor cool there fore temp. in fridg. will not be consistant.
Aug 05, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Refrigerator is not cooling properly
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Refrigerator not cooling properly.
upper part feeses and bottom not verry cold at all
Aug 16, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
RS267LBBP fridge is not getting cold even though turned temp down
hello , can you hear the compressor kick on ? and if so have you checked the door seal ?
Apr 05, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Defy Fridge temperature dial is confusing - which way is colder?
0 = off, 1 = cool, 2 = cooler, ..... 7 = coldest.  0 - 7 Nothing to do with the degree the fridge is set to.
Jan 07, 2009 | Refrigerators
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
1,150 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
