TFTP error pxe -t01 pxe-e3b: TFTP error - file not found
  • 137 Answers
Make sure the first boot device is the hard drive. or cd/dvd if you're installing OS
Posted on Jun 25, 2008
Rp 3105ep
www.riscogroup.com/support/downloads
Sep 14, 2014 | Ambient Recording ACD-301RF Master Radio...
Coad e61 will not clear by sig-time-sig-time and give me t01
Unfortunately you have a bad computer board that needs to be replaced. Apparently, a grounded fault found it's way there. I have seen this problem before and GE has a potential design flaw because too many machines are displaying this Error Code!!! I would Most definitely check with them and register a WRITTEN complaint!
Feb 18, 2014 | GE DBVH512EFWW Dryer
System error T01-521
Error type T01 [Main-motor lock]
T01-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset
Error point Error conditions
520
The main motor limit sensor does not go ON/OFF for more than 16 pulses while
the main motor is operating, even after the elapse of 100 ms.
521
The position-A sensor does not go ON/OFF, between two detections of position-B,
while the main motor is operating.
522
The position-B sensor does not go ON/OFF while the motor is operating, even
when 3033 pulses are received at the Main FG.
524
The clamp unit is not at the home position while the print drum is operating
(Clamp sensor C: OFF, except during master disposal).
536 The drum failed to stop at position A. (over-run)
537 The drum failed to stop at position B. (over-run)
538
The print
Sep 24, 2013 | Riso RP 3700
NO BOOTABLE DEVICE FOUND,
You probably have a mbr virus.
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Aug 18, 2012 | Intel Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
PXE booting errors
I don't have any experience with this product but I am 99.9% sure your problem is with Option 67. This path is from the root as defined for the TFTP server, i.e. root for the TFTP service is not the same as root for the server proper.
Most likely it should be something like:
\Boot\GhostNBF.vfd
Jul 13, 2009 | Microsoft Windows Server 2003 Enterprise...
Operating System Not Found
Hi and welcome to FixYa,
Almost always, your described problem indicates a hard disk problem: either it is no longer recognized (most likely) or the partition / files are corrupted.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Gateway M1200-3004265 Tablet PC
Hello all can you please help me on how to restore the configuration of my ASA 5520? thanx
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
Apr 01, 2009 | Cisco ASA 5520 Firewall
Debian on p655
Are you over thinking this? Have you checked the source and target media's file systems for 1: errors and 2: suitability of file system format? Have you confirmed the integrity of the source files? Questions like this can seem simplistic but when diagnosing any problem always start at the beginning. You are using an distro installer that is suitable for an IBM p655's architecture.
Aug 29, 2007 | IBM pSeries p655 Server
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
