Question about IBM ThinkPad T41 Notebook
Cmos how do you clear the cmos and where if any is the cmos jumpers. i took the both batteries out for two days now and still can get it to start, it show a little computer screen & a lock
  • banker505 Jun 26, 2008
    The problem started when i turned on the laptop, it booted pass post started win xp & then flashed blue screen (error), it restarted itself with a power on password lock.
    I removed the mian and the backup (cmos) battery for two days & still locked up
  • Eric Waggoner May 11, 2010
    By both batteries, do you mean main and CMOS, or do you have two main batteries?
    Genius:
  • 2,028 Answers
Is it asking for a password and did it just start doing this? Please give a little more info to the problem you're trying to fix. Some problems with IBM can be more difficult than others.
Posted on Jun 25, 2008
Led indicator lights
Following are the various ways to clear the CMOS or NVRAM on Optiplex systems:-
The computer must be disconnected from the electrical outlet to clear the CMOS setting.
Remove the computer cover.
Locate the CMOS battery on the system board.
Note the orientation of the battery, usually the plus side is up, and remove it.
Wait for 3 to 5 minutes for the CMOS to clear.
Replace the battery in the socket.
Replace the computer cover.
Plug the system and devices back into the electrical outlets and turn them on.
And Sec option jumper setting also available you can used:-
Turn off the computer and disconnect the power cable from the electrical outlet.
Locate the 3-pin CMOS jumper (RTCRST) on the system board.
Remove the jumper plug from pins 1 and 2.
Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
Replace the jumper plug on pins 1 and 2.
Close the computer cover.
And More Support see link:-
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-755_user's%20guide_en-us.pdf
If more Technical Support Call.
Aug 22, 2013 | Dell Optiplex 755 Desktop Desktop Computer...
On my e-machines t3418 motherboard what pin setting should the jumper be for clear cmos
1. Usually there are 3 pins, and you put the jumper on 2 of them to clear CMOS, then return them to the other 2 for normal function.
2. What you're describing seems more like a dead motherboard battery. Replace it and the computer should hold the time and date.
Nov 11, 2011 | E-Machines T3418 PC Desktop
Forgot the password and cannot start my laptop
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
Hope this helps
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps
Jan 25, 2011 | Computers & Internet
Clear cmos Dell dimension 3000. It don't have pin or jumper
Open the case and locate the CMOS battery. Just nest to it should be a button or jumper. Press the button or remove the jumper, then start the machine.
If it's a jumper, turn the machine off once more and replace the jumper before continuing.
Apr 28, 2009 | Computers & Internet
Bios Password reset for Toshiba Satellite M 45
Did you notice a PWD clear jumper while you had it open?
OR CMOS clear jumper?
Sep 28, 2008 | Computers & Internet
Please help me
Hi
Check ASROCK P4i45GV R5.0 User Manual Page 17 - http://download.asrock.com/manual/P4i45GV%20R5.0.pdf
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Regards
Mike
Mar 22, 2008 | Asrock P4I45GV R5 Motherboard
Bios doesnt show sata drive
remove the cmos battery and clear the cmos memory using jumper(it presents near cmos battery ,refer manual of motherboard)
restart the pc-now cmos setting screen appearce
save the bios settings usin F10 or refer onscreen
shutt down the pc ,reset the battery and jumper in original place
start the pc
now try
regards
prasanna
Mar 02, 2008 | Areca ARC-1210 Serial ATA Controller
CLEAR CMOS
First switch off at wall and remove power leads. The push on button to discharge capacitors on board.
 The jumper will be located near the bios battery and chip usually at the bottom right of motherboard. Move the jumper to the clear position and leave for a few mins. Then put back into normal postition and start pc up.
If that fails to clear it then repeat but remove the battery from the motherboard too and wait longer.
Hope that sorts it for you?
Jan 06, 2008 | Computers & Internet
IBM ThinkPad T41 Notebook Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
