Question about VeriFone Omni 3700
Paper I think we have our paper installed wrong. There is nothing printing on it. Could I get the instructions on how the paper should be installed, and if that's not the problem, could you tell me what I need to do next. Thank you Tina tina@nortonshores.org
  • 3 more comments
  • Anonymous Jul 08, 2008
    how to load paper
    how to load paper
  • Anonymous Sep 04, 2008
    how do i load the paper
  • Anonymous Jan 09, 2009
    need help NOW
  • Anonymous Feb 20, 2009
    we cannot load new paper roll into machine
You could have a malfunctioning printer. If you have turned the paper around and it still does not print, then call your processor and get a replacement unit.
Posted on Jul 01, 2008
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
Hi, i have a TLP 2844 printer Thermal, but i cant print labels. I have read the manual and follow the instructions. Every time i put labels on the printer, only send me blanks. Can you help me, please
Are you trying to print in thermal or thermal transfer mode? If thermal transfer mode, do you have the ribbon install correctly with the coated side facing towards the label? If using thermal mode, are you using thermal paper and are you trying to print on the coated side? Hold the feed button down and turn the printer on. Hold it down until the light stops flashing. At this point the printer will print a diagnostic dump. If nothing prints then either you have the media loaded wrong or something else is wrong with the printer.
Jul 19, 2011 | Zebra LP 2844 Thermal Printer
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
Printer sounds as if it is printing, paper runs through,
Have you tried to clean the nozzles?
Did you print a test page after installing the new cartriddge?
Go there http://www.lexmark.com/publications/pdfs/z33/enuserlx.pdf
Sep 26, 2009 | Lexmark Color JetPrinter Z23 InkJet
Same or similar problem
Try to download the updated driver for this printer, I have the same problem and solved with the newest driver.
Jul 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
Can't Print
Firstly, I have to ask......the paper is installed, and tray set correctly? Does it read the proper size on the display of the copier?
Ok....next, do you have the optional paper trays installed (3 & 4)?
Is that where the 11 x 17 paper is? Then you probably did not add the accessories when you installed the driver and when printing that paper is unavailable.
right click your printer icon, click "properties", then i think it's under the "accessories" , or "options" button....select the optional trays, and anything else you may have. click 'ok' ...should work.
Mar 19, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
CX3810 printer will not print
Take out the cartridges from the printer, put them back.
Remove the printer completely from your computer. Reboot. Re-install the printer.
Try to print again.
It sounds like your print heads are shot.
Nov 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Lexmark z23 will not print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Sep 12, 2008 | Lexmark Color JetPrinter Z23 InkJet
Printer malfunction
Diagnostic pages are usually internal to the printer- not generated in the PC. Scanning and printing can also be PC Independant[ like printing photos from media cards in ther stand alone mode - No PC required. So go back to the printer. Go to start/printers and faxes- dig out out the driver CD and reinstall- make sure when this is going on you direct the comm away from LPT1 to a USB setting. Do that then come back.
May 07, 2007 | HP PSC 2175 All-In-One InkJet Printer
Retail Supplies Logo
156 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
